What't the best current model for towing?
Discussion in 'Towing' started by Spencer97TJ, Oct 7, 2014.
  1. Oct 7, 2014 at 4:32 AM
    Spencer97TJ
    Spencer97TJ [OP] Well-Known Member
    Spence
    CT
    stock
    I am looking for a new or low mileage double cab tacoma. I am very new to tacomas. I swear I saw a long bed double cab recently.
    If you guys were to buy a tacoma for towing today, which model would you get?
    I am towing an 18 foot travel trailer. A Jeep Liberty pulls it ok, but I want to upgrade to a Double Cab Taco.
    Thanks!
  2. Oct 7, 2014 at 6:50 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    Any of the V6 models should pull that trailer nicely. A TRD Sport or Off Road will come with the tow package. Just make sure you get the factory tow package which has a bigger alternator, battery, a transmission cooler and of course the hitch and harness.
  3. Oct 7, 2014 at 6:59 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    the above - but also with automatic transmission.
    The V6 with 6 speed manual is not well suited to towing heavy trailers.
  4. Oct 7, 2014 at 7:03 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Tows mine fine and I can even use 6th gear how about your automatic use O/D much?
  5. Oct 7, 2014 at 7:10 AM
    rademan11
    rademan11 Well-Known Member
    DFW TEXAS
    4X4 trd off road
    Ranch Topper, Bull Bar.....Yes, I know everyone thinks they are crap, I like the look
    My self imposed rule is try not to pull more than 2/3s of the rated towing capacity.
    My experience has been the closer you get to max weight, the worse the truck gets.
    Up hills, acceleration etc. all become intolerable close to max weight.
    If your going to be pushing the weight rating with your trailer, might want to look at a bigger truck.
  6. Oct 7, 2014 at 8:10 AM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's been a couple years - but there was a member on here who went round and round with the dealer on warranty repair of the 6 speed.
    Ultimately, the tech investigation department resolution was to get the dealer to trade him into an AT model.
    The usage pattern was, IIRC, that he used a heavy travel trailer - right at the weight limit - and often had to back it into a slightly uphill parking/camping spot.
    So the transmission failed multiple times in the same way. Pretty much ever since, the "TW collective wisdom" has been to avoid the 6 speed for towing heavy trailers.
    I don't have a chip on my shoulder about it and I'm glad yours is working well for you.
  7. Oct 8, 2014 at 3:59 AM
    Spencer97TJ
    Spence
    CT
    stock
    Thanks for the reply. I love manuals, but I still have a modded 5 speed TJ to get that experience. :)
    I am towing a 18 ft fun finder and don't have plans for a bigger camper.
    http://www.cruiserrv.com/products/fun-finder/floorplans/item/f-189fbs
    Axle Weight (lbs) 2,865
    Hitch Weight (lbs) 290
    Dry Weight (lbs) 3,155
    Cargo Capacity (lbs) 2,735
    A 3.7 ltr libby pulls it OK (just OK) with sway bars and a brake controller, but I just want something a step up from that.
  8. Oct 8, 2014 at 4:12 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    IMHO, the longer wheelbase truck should do a better job. When you get your truck, you should consider getting the ProEFX towing mirrors, they make a huge difference. Thread OP (mach1man001) will probably do another group buy in the Spring. If you can't wait, his company usually has them in stock. Good luck finding the right truck. :cool:
  9. Oct 8, 2014 at 4:16 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    I would think a double cab long bed would be best for towing due to the longer wheelbase (stability).
    Or maybe I'm just biased.
  10. Oct 8, 2014 at 5:35 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    I think you would notice a big differenece if you stepped up to a Taco. The Tacoma would have no probelm pulling that trailer.
    Thanks Rob
    X2.
    The only thing is that you can not get a double cab long bed with the manual transmission so if you want a 6 speed you can get a DBL Cab short bed. If you want an auto you can get it with either long or short bed. GL
  11. Oct 8, 2014 at 5:35 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Well in his case the clutch should have failed before the gear box the trans is capable of towing any thing up to the rated load or they would never sold a truck with a factory hitch. Sounds more like driver error than a bad trans. The 6 spd. is rated for a lot more torque that the engine is capable delivering so unless it's abused it should not have failed.
  12. Oct 8, 2014 at 10:54 AM
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Sport has an addition leaf spring... not that its worth a shit. New leafs should be in order either way
  13. Oct 8, 2014 at 11:53 AM
    oldstick
    oldstick Medicare Member
    GA
    + 1 on that. Double cab, either long or short as long as it has the factory two pkg. And I will cast a vote for Pre-Runner IF you don't need 4x4 because of the slightly lesser overall weight.
  14. Oct 9, 2014 at 5:28 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    That thing is pretty heavy loaded it probably pulls fine with twin axles but I bet hills are a killer my 18' is less than 4,000 loaded but it has no slide out. Don't expect much over 10-12 MPG.
  15. Jan 24, 2015 at 4:04 PM
    Spencer97TJ
    Spence
    CT
    stock
    just realized that there was a ton of great replies to this.. Well, I have a deposit down on a 2009, sr5 with 58k on it. It fit the budget, and is clean.
    OK.. It DOES NOT have the tow package. How much of an issue is it going to be to set it up right for this rv? I have another thread started about needing a tranny cooler. Can I cool this transmission with a simple add on? Do I need to cool it? Did I mess up?
  16. Jan 25, 2015 at 5:11 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You are OK I would surly add a trans cooler. Not having the tow package does drop your capacity as far as Toyota is concerned all though the aftermarket hitch is rated for the load there is a difference the factory one is also bolted to the truck bumper it has no oil cooler or trans cooler a smaller battery and lower output alternator. You will also need to install a brake controller there will be those that say it's not needed but all most every state says you need to have one with a trailer above 1,000# and for good reason. If your trailer is a single axle you also might find that a sway bar would be an asset. I have an 18' with dual axles just about the size you are looking at and I have been every where with it even towing it with the dreaded 6spd for the last 55K miles. Frankly if you enjoy camping you picked a great size trailer to match the truck and it will be easy to tow with out white knuckles.
  17. Jan 25, 2015 at 3:22 PM
    Spencer97TJ
    Spence
    CT
    stock
    Hey Man, this was the clincher! The deals off. I will be annoyed every single time I make a payment on a rig that's not what I really wanted. Can't swing new right now with other things going on.. So, waiting it out. I need less worries with my tow rig. Towing the funfinder with a liberty (it works, but it's a struggle at times). can't be worrying about adding coolers, hitches etc when for a grand or so more, I can get the tow package.
    Thanks for the great advice guys. Almost a costly mess up.
  18. Jan 26, 2015 at 4:50 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can get the tow package on any V6 Taco and be happy. If you are buying new I think it has a $650 price tag by the time I bought mine it was down to $150 as part of the over all deal. There should be plenty of used ones out there with the package it's a popular option. You will be a lot happier with the Tacoma over the Liberty towing your camper. That's a nice looking camper.
  19. Jan 27, 2015 at 11:47 AM
    F-125Racer
    F-125Racer Well-Known Member
    Arkansas
    09,DC,TRD Sport, 4WD, TRD S/C
    Good call, you won't regret passing on this one.
  20. Jan 29, 2015 at 4:18 PM
    Spencer97TJ
    Spence
    CT
    stock
    Found a sweet 2012 sr5 w towing package. Thanks to you guys I knew what I was looking for. The cooler. The hitch bolted to the bumper. Made the decision easy. This forum is sweet.
    Thanks for helpin a Jp guy out.
