Wheel base/ driveshaft length
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Masshole_And_His_Taco, Dec 14, 2017.
  1. Dec 14, 2017 at 10:09 AM
    Masshole_And_His_Taco [OP] RIP Rick
    Northish South Shore MA
    Two-seater Curb-eater
    Little bit of stuff.
    So I have a relatively simple question, did some research to no avail, so I'm just gonna fire it into the void and see what I get. Can anyone confirm for me whether or not the wheel base of my 06 Access cab long bed 4WD is the same as that of a 2nd gen dbl cab short bed 4wd? I ask this because I want to know if the one piece driveshaft I'm looking to purchase will fit. Just asked the seller for a length measurement, but I'd also like to hear your input.
  2. Dec 14, 2017 at 11:09 AM
    Pigpen
    Dan
    Northwest Montana
    Access Cab and DCSB have the same frame and same size drive shaft.
