Wheel bearing ABS Rotor?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eyball, May 14, 2011.
  1. May 14, 2011 at 5:28 PM
    eyball
    eyball [OP] Well-Known Member
    Quinebaug, CT
    05 Double Cab SR5 V6
    Extang Tri-Fecta Tonneau cover, Westin nerf bars, K&N intake, OEM roof rack.
  2. May 14, 2011 at 5:32 PM
    eyball
    Quinebaug, CT
  3. May 14, 2011 at 7:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    All trucks have ABS but not all replacement parts have ABS ring in them. In theory you should be able to press old ring out and new ring in, but I have to say pressing ABS ring has 50/50 chance of success. Any slip and it won't work correctly and no way to find that out until everything is back together and driving. ;)
  4. May 14, 2011 at 7:35 PM
    earnesje
    earnesje Active Member
    Jacksonville Fla
    2011 Nissan Frontier King Cab SV V6 6SPD MAN
    One is probably for 4x4/prerunner and the other is for 2wd.
  5. May 14, 2011 at 7:38 PM
    eyball
    Quinebaug, CT
    Why would I even need to remove the ABS ring?
    Isnt it pressed into the knuckle behind the bearing.?
    Both of these say they work with 4wd.
  6. May 14, 2011 at 8:38 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    06 DC 4x4 TRD Off-Road
    Get the Timken if they have them in stock. Timken are very good quality. I was not able to find them in stock anywhere last summer.
  7. May 15, 2011 at 7:41 AM
    BlueT
    NorthEast
  8. May 15, 2011 at 8:08 AM
    eyball
    Quinebaug, CT
    I believe that is a rear bearing unit. I don't think you can buy a bolt on solution I think they all have to be pressed together with the hub.
