Wheel bearing concern on my 2004 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by bassTaco, Oct 3, 2011.
  1. Oct 3, 2011 at 12:50 PM
    bassTaco
    bassTaco [OP] Active Member
    Rick
    Austin, TX
    04 Tacoma D-Cab Prerunner V6
    Just yesterday I replaced the rotors and pads on the front wheels of my 2004 Tacoma Dbl-Cab Prerunner. While doing this work I noticed on the passenger side that there was a lot of grease buildup and brake dust collected behind the axle hub. Also, the hub required a little more pressure to rotate it compared to the driver side. I should have taken some pictures to show you guys but do you guys know if this could be a problem with the wheel bearings? It did not seem like there was play in the axle hub. Any thoughts?
    Thanks,
    Rick
  2. Oct 3, 2011 at 8:18 PM
    Mig98Taco
    Mig98Taco Well-Known Member
    Miguel
    So. Cal
    I thought I had noticed a noise, so I opened up the wheel bearings and inspected them, cleaned them and regreased them, the grease in there was not for wheel bearing it was much thicker so I guess someone at one point decided to put any grease there.
    best bet is to open it and take it apart.
  3. Oct 4, 2011 at 11:45 AM
    bassTaco
    Rick
    Austin, TX
    Thanks Mig98Taco! So I thought the wheel bearings are pressed? Is that not true? Not sure how different the wheel bearing designs are between the 98 and 04 models though.
  4. Oct 4, 2011 at 4:50 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I re-did my rear wheel bearing on my 96 and it had to be pressed. In fact, it was so hard to get out that it had to be heated.
  5. Oct 4, 2011 at 4:58 PM
    KID3
    KID3 Well-Known Member
    las cruces NM
    01 DC taco 4x4 sr5 trd
    lots
    yea the rear bearings have to be pressed on and off. there are two res on each side of the bearing very seldom can they be taken off without cutting them off. impossible to do at home in the garage unless you have some heavy duty press.
  6. Oct 4, 2011 at 5:01 PM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    front bearings are sealed and must be pressed in. these are not serviceable parts, and cannot be "regreased". Roughly 90 bucks a pop from autozone, but avoid these like the plague. I wish i had.
  7. Oct 4, 2011 at 9:35 PM
    bassTaco
    Rick
    Austin, TX
    Thanks for the replies! I think I will not worry too much about it. I don't hear any noise indicating a problem and there isn't any play on the axle hub. I'll probably check the temperature of the wheel after a drive just to make certain its not getting really hot.
