Wheel bearing going out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tomwilson74, May 21, 2018.
  1. May 21, 2018 at 3:16 AM
    tomwilson74
    tomwilson74 [OP] Well-Known Member
    Tom
    West Virginia
    2020 TRD double cab OR
    OME 3” lift Mickey Thompson Classic III Wheels
    I think I have a wheel bearing going out. I have a 2012 OR with 130,000 miles on it. I’m getting a vibration in the steering wheel st around 60mph. Worse on curves to the right. Feels like the left front wheel. Any ideas?
  2. May 21, 2018 at 3:26 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2019 magnetic gray DCLB
    Sounds like it...
  3. May 21, 2018 at 3:28 AM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
    Jack it up and see if there is play in the wheel?
    tomwilson74[OP] likes this.
  4. May 21, 2018 at 5:11 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    jack the front up so both wheels are off the ground, and wiggle the wheel back and forth. if there is no play spin the tire and see if you hear any grinding. if there is play in the wheel make sure you check other things that will cause that such as inner and outer tie rods, lower and upper control arms with the ball joints, and a shitty axle
  5. May 21, 2018 at 6:24 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You mention vibration, but what about noise? Seems to me a bad wheel bearing would be talking to you.
    tomwilson74[OP] and ChadsPride like this.
  6. May 21, 2018 at 6:46 AM
    Muddinfun
    Muddinfun Well-Known Member
    Could also be a tire with a broken belt. When you spin the tires, look for a bulge in the tread. Easiest to watch the distance between the tread and the ground while spinning.
  7. May 21, 2018 at 6:49 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    steady groan that goes faster with speed
    I didn't have any vibes like that when mine was bad
    maybe you have a loose lugnutor two
  8. May 21, 2018 at 10:43 PM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Yeah, noise changes in a turn is a dead giveaway. If you jack it up and can wiggle top to bottom it's definitely gone
  9. May 22, 2018 at 12:15 AM
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I just replaced both of mine with less than 70K miles. Initially thought it was the driver’s side. Vibration would go away on long right curves.
    Changed drivers wheel bearing and needle bearing but vibration was still there. The vibration would get worse around 50mph, enough to vibrate the keys in my ignition.
    I replaced the passengers and the vibration went away. No extra play or grinding on either side with wheels off the ground. The bad bearing did have a dead spot in it where it would bind when spun freely once removed.
    -RJM
    tomwilson74[OP] and 05Taco4x4 like this.
