Wheel bearing/hub stuck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgfuson, Mar 25, 2016.
  1. Mar 25, 2016 at 7:10 AM
    mgfuson
    mgfuson [OP] Active Member
    2010 Tacoma 4x4 DCLB
    King 2.5 with remote reservoirs and 650# coils, SPC UCA, 5100's, Dakars, Pelfreybilt Aluminum front, Pelfreybilt Hi Clearance rear, 16x8 Relations Race RR4 in matte bronze, 285/75r16 KO2's, custom bed rack, FSR RTT.
    anyone have any tips or tricks for freeing a hub assembly stuck to the spindle. All the bolts are loose and I've beat it with a hammer and tried to pry it off with a screwdriver (already broke two.) Any help would be greatly appreciated.
  2. Mar 25, 2016 at 8:48 AM
    Tacoma005
    Tacoma005 Well-Known Member
    Bellingham, WA
    2005 DCSB TRD Off-Road 4X4
    KMC Crank Rims, 30" Baja Designs light bar, HomerTaco front grill
    Maybe some PB Blaster spray?
  3. Mar 25, 2016 at 12:34 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    jack truck up loosen bolts & drop truck ??
  4. Mar 25, 2016 at 12:38 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    So you removed the 4 bolts on the back of the hub?
    I have a 2009 and I didn't have any issues replacing both of my hubs. Not sure what you're following but here is a how-to
    https://www.tacomaworld.com/threads...e-replace-front-wheel-bearing-2nd-gen.189356/
  5. Mar 25, 2016 at 12:50 PM
    MrDibblesTaco
    MrDibblesTaco Well-Known Member
    Kevin
    2009 White Tacoma SR5
    3" Lift, ARB Front Bumper, Canopy, BFG Allterains, 17x9 XD wheels
    1. make sure your speed sensor is removed from the spindle..
    2. If you have a Oriliey's or Autozone they have a tool rental.. You can rent a hub puller. Just a big slide hammer. Go to town on it. Best trick is just to work around it side to side smacking the hell outta it.
    3.. Drink a beer and call it dirty names....
  6. Mar 25, 2016 at 12:53 PM
    Ahougland89
    Ahougland89 Well-Known Member
    Anthony
    Orting, Washington
    2007 Tacoma 4x4 6spd Manual
    3inch lift 33inch TOYO M/T
    After loosening the bolts you have to tap around it with a hammer and then keep loosening the bolts.
  7. Apr 30, 2016 at 6:46 PM
    mt1961
    mt1961 Well-Known Member
    Kingsport, TN
    2015 TRD Sport
    Changed mine last night. When you get the 4 hub bolts loose put something metal, I used metal shims, between the head of two of the bolts and the outside flange. Then as you unscrew the bolts it will pull the hub out of the spindle.
