Wheel bearing replacement 98 toy 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by 67tone67, May 31, 2011.
  1. May 31, 2011 at 6:48 PM
    67tone67
    67tone67 [OP] Well-Known Member
    Tony
    Fulton Ms
    04 Dbl cab TRD
    My truck is all jacked up ..... Ready for wheel bearing replacement... Having trouble finding a worded guide and not a diagram online! I removed my lockout cover plate but cant seem to get the lockout base loose from the hub! Saw somethhjng about cone washers in diagram? I removed all bolts and washers ( i thought) anyone ben here done that? Thanks.
  2. May 31, 2011 at 9:33 PM
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    Is this for your rear wheel bearing?
    There is a collar. You will have to grind it off, then air hammer it to break it off. All comes apart then. I know cos this took me 2 hours to figure out :)
  3. Jun 1, 2011 at 3:27 AM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
    No. Its the front bearing.
  4. Jun 1, 2011 at 9:59 AM
    96Taco
    Alberta
    2014 DBL CAB Tacoma
    Have you checked the FSM?
  5. Jun 1, 2011 at 12:58 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Ncttora.com/fsm
  6. Jun 1, 2011 at 7:00 PM
    67tone67
    Tony
    Fulton Ms
    04 Dbl cab TRD
  7. Jun 1, 2011 at 7:11 PM
    medic2230
    Murph
    Bama! Roll Tide
    Factory Service Manual
    It's online at the above website.
