Wheel Bearing Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by seniorredwood, Jun 6, 2017.
  1. Nov 21, 2022 at 3:58 PM
    #141
    Mastiff37
    Mastiff37 Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    Reviving this thread with a question. The bearing nut calls for a 35mm socket. I have a 1 3/8 socket, which is 34.925 mm. Opinions on whether it's close enough? I'm no expert, but I'd be skeptical the tolerances on a 35mm socket are tighter than that for most ones off the rack.
  2. Nov 21, 2022 at 4:40 PM
    #142
    YanosAldrin
    YanosAldrin Mud(ling) my way through.
    Sean
    Colorado
    2009 Taco, 4.0L 4x4 Dbl Cab
    6" Coil-over suspension lift kit from BDS Suspension (2.5 Coil-Over FOX remote reservoir, 2.0 FOX rear) 18x9 Eagle Wheels w/ 285/65/R18 Nitto Grapplers
    You could always pop off your wheel center cap, cotter pin and that secondary metal cover thing (forgot what it's called) and see if it fits, I've also seen via YouTube someone use 36mm with no issues.
  3. Nov 21, 2022 at 4:47 PM
    #143
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It should work fine.
    It’s worked for others.
    I’d rather it be tighter than looser.
    https://www.tacomaworld.com/threads/axle-nut-size-torque-spec-09-taco-4wd.327073/
    Mastiff37[QUOTED] likes this.
  4. Nov 26, 2022 at 8:09 AM
    #144
    Mastiff37
    Tucson, AZ
    Just finished this job (wheel bearing assemblies) and here are some comments for people yet to do it:
    • Even on my Arizona truck the rotors were totally stuck on. If you are not on a budget I recommend buying new rotors so you can hammer the old ones off with impunity. One of mine was badly grooved anyway.
    • The dust cap was a surprising PITA to deal with. For removal, use a chisel in the slot, not a screwdriver. Once it is barely started, get the steepest angle you can from the back and work around slowly. One of mine was really hard to get back on. Super frustrating so be prepared.
    • My caliper bolts were really tight and there's not much angle to get an air gun in there. I ended up using a breaker bar to get them started, then hammered on a box wrench until they were loose enough.
    • I saw videos of people hammering the bearing assembly off, but I had a "universal puller" from Harbor Freight and it made the job easy and controllable.
    • Don't forget to put the dust shield back on before you install the new bearing, just sayin'.
    • I took this from a youtube video: To torque the big bearing but, put a metal rod through the lug nuts at an angle against the floor to prevent rotation. Worked like a charm.
    • Might as well do the brakes while you're at it. I chose not to do the seals since it all looked clean.
    TheDevilYouLove likes this.
  5. Nov 26, 2022 at 8:25 AM
    #145
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    I thoght there were two threaded holes 180 degress apart on the rotor assembly that accepted M6 (?) bolts that would pull/push the rotor off as they are tightened. I could be wrong, it has been a while...
  6. Nov 26, 2022 at 8:28 AM
    #146
    Mastiff37
    Tucson, AZ
    There are. I've heard it's common for these to strip out, but I had no metric bolts around to give it a try. Given that I had to use a mini sledge to pound it off, I'm slightly skeptical those little threaded holes could have done the job.
    Woofer2609 likes this.
  7. Nov 26, 2022 at 8:36 AM
    #147
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    They work well, or they did on mine, anyway. As an aside, It took me 30 years of wrenching, but I have started using nickel anti seize compound on anything i think may ever need to come apart in the future, and Loc tite if it shouldn't. The stuff is gold (well, nickel, but you know what I mean;).
  8. Nov 26, 2022 at 8:59 AM
    #148
    Mastiff37
    Tucson, AZ
    I'm a fan of anti-seize too. I am a little cautious though. One time I used it liberally on some leaf spring U-bolts and they ended up loosening up off road and the axle fell out. Not a good day. One could argue that there was more involved, but that's always in my mind when I used anti-seize on things. I chose not to anti-seize the bearing assembly bolts. Incidentally, the bolts appeared to be pre-treated with a small amount of loc-tite if I'm not mistaken.
  9. Nov 26, 2022 at 11:30 AM
    #149
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Did you guys grease the center of the rotors before reinstalling them? Thats where corrosion builds up and binds the rotor to the hub. Use a wire brush to clean it up and apply grease before installation so next time they are easy to remove.
  10. Nov 26, 2022 at 1:22 PM
    #150
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    My son (a Toyota / Lexus Tech) and I use Castle spray on High Temperature Anti Seize. (The copper stuff.) I wouldn't recommend grease due to the high heat generated in your brakes and the likelihood that the grease might liquify and run onto the braking surface.
  11. Nov 26, 2022 at 2:14 PM
    #151
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    Yes, but I use anti seize compound, not grease.
  12. Nov 26, 2022 at 2:15 PM
    #152
    Woofer2609
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    I hear ya! It's a bit of a calculation as to where to apply each!
  13. Nov 26, 2022 at 2:32 PM
    #153
    Mastiff37
    Tucson, AZ
    Yeah, I put some anti-seize on the hub where the rotor mates. A video I watched put it on the bearing assembly mating surface, but mine was not stuck there at all. The dust shield is in-between so it seemed pointless.
    TnShooter likes this.
  14. Nov 26, 2022 at 2:34 PM
    #154
    Chuy
    Lakeside, CA
    Silver Taco
    I can assure that doesn't happen, maybe if you put gobs of it. I have been using the same tub of high temp bearing grease for some 20+ years and have never observed any liquification.
  15. Nov 26, 2022 at 2:34 PM
    #155
    TnShooter
    Deogee
    STOCK
    I used blue loctitie on the hub bolts.
    One of my assemblies also had the pre-applied loctite. I did not use it on that one. But the dry type made threading the bolts in slow. As I had to use the boxes in the whole way in.
    I used Lucas Red n’ Tacky.
  16. Nov 26, 2022 at 2:36 PM
    #156
    TnShooter
    Deogee
    STOCK
    I didn’t use anti-seize anywhere.
    Loctite on the bolts. And grease on the axle splines.
  17. Nov 26, 2022 at 2:44 PM
    #157
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    When i did mine last spring i used the bolt that holds on the horn bracket
    Of course i did the wrong side and had to do the other side a week later
    Used the same bolt
