Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$ CUSTOM BUILT AVAILABLE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by nj636, Jul 25, 2013.
Thread Status:
Not open for further replies.
  1. Dec 28, 2015 at 7:11 AM
    #2161
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    My drivers side has been getting worse over the past few months, it is really roaring now. Planning on ordering today from nj636. Is it a good idea to just replace the passenger side while I'm at it, regardless if it needs it or not?
    nj636[OP] likes this.
  2. Dec 28, 2015 at 8:04 AM
    #2162
    G.T.
    G.T.
    CONUS
    I look at it like I do headlight bulbs. Replace both at the same time so that you aren't left guessing when the old one will give up the ghost. Besides, you already have all the tools out and the second one always goes faster than the first. Saves you from having to stop everything a second time to tear apart the other side.
  3. Dec 28, 2015 at 8:05 AM
    #2163
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    I've always recommended to do both, one usually follows the other. It's an easier reference to maintenance as well knowing when you changed the parts.
    ecoterragaia[QUOTED] likes this.
  4. Dec 28, 2015 at 8:09 AM
    #2164
    nj636
    Kev
    Jersey
    agreed, unfortunately the bearings are a wear item & will need to be replaced at some point.
    it's like replacing the passenger spark plugs but not the driver side.
  5. Dec 28, 2015 at 8:14 AM
    #2165
    ecoterragaia
    Central Virginia
    Sounds good, thanks. I will be ordering them today when I get home. I guess I will also be needing a 35 mm socket too, based on the previous write-ups. Doesnt look too hard.
  6. Dec 28, 2015 at 8:22 AM
    #2166
    nj636
    Kev
    Jersey
    It's very easy with basic tools, a 35mm socket & a torque wrench capable of 173 ft/lbs. You can rent one at a local parts store if you don't have one.
    If you have ever had the brakes off the truck, you are only a few bolts away from removing the hub assembly.
  7. Dec 28, 2015 at 8:39 AM
    #2167
    ecoterragaia
    Central Virginia
    Thanks man, other than the socket, I have the other tools. Never had a need for that size before.
  8. Dec 29, 2015 at 4:05 PM
    #2168
    nj636
    Kev
    Jersey
    not a problem, I have a lonely 35mm as well :)
  9. Dec 29, 2015 at 4:06 PM
    #2169
    nj636
    Kev
    Jersey
    Tracking info has been PM'd :cheers:
  10. Dec 29, 2015 at 5:09 PM
    #2170
    ecoterragaia
    Central Virginia
    That was quick, tracking info 6 hours after ordering. Thanks man!! Can't wait to have a quiet truck again. :thumbsup:
    nj636[QUOTED][OP] likes this.
  11. Dec 30, 2015 at 12:18 PM
    #2171
    nj636
    Kev
    Jersey
    you got it man, thank you for the purchase.
  12. Jan 2, 2016 at 2:02 PM
    #2172
    nj636
    Kev
    Jersey
    Happy New Year :cheers: :drunk:
  13. Jan 5, 2016 at 1:23 PM
    #2173
    nj636
    Kev
    Jersey
    PM'ing tracking info this evening :thumbsup:
  14. Jan 5, 2016 at 6:26 PM
    #2174
    ecoterragaia
    Central Virginia
    Thanks!
  15. Jan 6, 2016 at 8:16 AM
    #2175
    Auburnslim
    Auburnslim Member
    2011 4x4 trd sport double cab
    sub'd
  16. Jan 6, 2016 at 8:22 AM
    #2176
    Auburnslim
    Auburnslim Member
    Happy New Year to you too sir...Is there a difference at all between the Tacomas and a 4runner hub? I need to replace the fronts on my 01 runner.
  17. Jan 6, 2016 at 6:21 PM
    #2177
    nj636
    Kev
    Jersey
    Your 01 4Runner is similar to the first gen tacomas.
    The bearing is pressed into the spindle. you need a bearing puller or remove the spindle and press the bearing out.
  18. Jan 6, 2016 at 7:22 PM
    #2178
    ecoterragaia
    Central Virginia
    Finally found a 35 mm socket, had to go to a specialty tool shop as none of the chain stores had one. Ready to get those hubs off now!
  19. Jan 7, 2016 at 8:54 AM
    #2179
    Auburnslim
    Auburnslim Member
    Do you sell that assembly? I didn't see anywhere on the your webpage where to select a 4runner instead of a tacoma?
  20. Jan 7, 2016 at 6:00 PM
    #2180
    nj636
    Kev
    Jersey
    yeah, not a common sized socket especially in an Auto Zone/Advance Auto
Thread Status:
