Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$ CUSTOM BUILT AVAILABLE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by nj636, Jul 25, 2013.
Thread Status:
Not open for further replies.
  1. Dec 26, 2013 at 3:51 PM
    #561
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    it's an 8mm bolt which can be found under the hood :cool:
    you can always push the pistons back into the caliper to make it easier going back on.
  2. Dec 26, 2013 at 3:55 PM
    #562
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Thanks to nj636 for the hub/bearing assemblies.
    my old bearing next to the new set-up with extended studs.
    heres a crappy pic of my lugs on stock studs (shitty pic)
    heres the same thing w/ the new studs. MUCH more thread contact.
  3. Dec 26, 2013 at 5:52 PM
    #563
    DryCreek
    DryCreek Well-Known Member
    Utah
    08 DCLB TRD Sport
    Pioneer AVH-X2600BT Fog Anytime Trailer Plug Relocate (bullaculla) Ride Rite Air Bags OEM Roof Rack Rearview Camera Wet Okole Seat Covers Maxpedition Holster SOS Sliders Washable Cabin Filter Access Bed Cover K&N Drop In Filter Rearview Mirror Relocate (ImMrYo)
    Subd and PM sent.......picked up a precision bearing assembly and was going to try and tackle the replacement tomorrow. This looks much easier and has me rethinking.
  4. Dec 27, 2013 at 5:52 AM
    #564
    nj636
    Kev
    Jersey
    Thanks for the pics & feedback Jarel, glad you happy with them :D
  5. Dec 27, 2013 at 7:50 AM
    #565
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Is there any need to get a wheel alignment after doing this ?:confused: Thanks. Curious George
  6. Dec 27, 2013 at 8:54 AM
    #566
    nj636
    Kev
    Jersey
    No need for an alignment unless your replacing any suspension components.
  7. Dec 27, 2013 at 9:16 AM
    #567
    george3
    New Jersey
    Thanks.
  8. Dec 27, 2013 at 9:27 AM
    #568
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    No.....you don't touch the suspension. Its simply removing the brake parts and then the hub assembly and reversing the process.
  9. Dec 27, 2013 at 10:08 AM
    #569
    george3
    New Jersey
    Thanks.
  10. Dec 27, 2013 at 10:16 AM
    #570
    george3
    New Jersey
    I got another question for y'all. I did a brake job and replaced the OEM rotors. The OEM rotors came off by putting a bolt in the provided threaded holes and backing it off - easy. The new rotors don't have threaded holes. What's a easy way to remove them which I'll have to do to replace the hub assembly. Thanks.
  11. Dec 27, 2013 at 11:34 AM
    #571
    nj636
    Kev
    Jersey
    ^^^^^nailed it^^^^^
    definitely go for the dead blow hammer so you don't damage the rotor surface.
    I always use anti seize on the rotor to hub surface, a little bit goes a long way :thumbsup:
  12. Dec 27, 2013 at 11:36 AM
    #572
    Severe
    Severe Member
    2006 DC Tacoma 4x4 SR5
    Success! I literally just completed changing out both of my front hub assemblies and a test ride. It was amazing the difference!
    Thanks nj636 for your assistance and product! You saved me close to $1100 over what I would have paid to Toyota for the same results.
    FYI, anyone looking for the bolt to assist in the removal of the rotor, just pull one of the bolts off the air intake where it bolts to the fender well. That worked like a champ and make removal beyond easy.
    I'm not sure if this is appropriate or not but I found the following .pdf files invaluable in understanding what I needed to do to complete this task:
    http://tinyurl.com/pyyvhoh
    http://tinyurl.com/qjc5ocz
    http://tinyurl.com/oxlcboo
    http://tinyurl.com/ovomuc5
    I'm not a mechanically inclined person but this is a very do-able task. I will add, that I had to rent a 1/2" torque wrench and the 35mm socket for the axel nut. Beyond that, I completed the installation with some very back tools. Total time for me was about 3.5 hours.
    Thanks again and Happy New Year!
  13. Dec 27, 2013 at 1:41 PM
    #573
    george3
    New Jersey
    Thanks guys. I did use anti-seize compound so I should be good with the deadblow hammer and that won't mess up the rotor. Thanks again.
  14. Dec 30, 2013 at 7:01 AM
    #574
    TRD6Speed
    Bill
    East Hartford, CT
    Another very happy customer. Kevin shipped mine out on Sat.......here by 10am today. Looking forward to a smooth ride again. Thanks again Kevin.
  15. Dec 30, 2013 at 8:23 AM
    #575
    nj636
    Kev
    Jersey
    Glad I could help Bill :cool:
  16. Dec 31, 2013 at 12:08 PM
    #576
    nj636
    Kev
    Jersey
    Thank you to everyone for a great half of 2013, I'm looking forward to 2014
    :proposetoast:
  17. Jan 2, 2014 at 7:04 PM
    #577
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Installed both new hubs yesterday. Had a full day of driving around today, this is the best and quitest my truck has driven in a long time.
  18. Jan 2, 2014 at 8:36 PM
    #578
    nj636
    Kev
    Jersey
    glad I could help :D
  19. Jan 5, 2014 at 1:47 PM
    #579
    nj636
    Kev
    Jersey
    Off to a great start this year, thank you everyone for keeping this going :D
  20. Jan 7, 2014 at 3:35 PM
    #580
    nj636
    Kev
    Jersey
    all PM's replied to :cool:
Thread Status:
