Wheel Bearings/Hubs 4x4 & 4x2 PreRunner for sale *complete* save $$ CUSTOM BUILT AVAILABLE
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by nj636, Jul 25, 2013.
Thread Status:
Not open for further replies.
  1. Sep 29, 2015 at 5:05 PM
    #1941
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    So are you saying you have to disassemble the spindle from the top UCA and the hub to get the bearing cartridge out? Much more expensive I suppose to?
  2. Sep 29, 2015 at 6:29 PM
    #1942
    nj636
    nj636 [OP] Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    you can remove the bearing with a puller or remove the entire spindle and press everything out
  3. Sep 29, 2015 at 7:28 PM
    #1943
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Ok thanks
  4. Oct 1, 2015 at 7:48 AM
    #1944
    NBFJCruz
    NBFJCruz Well-Known Member
    Brian
    Saint John, New Brunswick, Canada
    2007 FJ Cruiser 5AT, lifted, 285's, black-out
    lifted, 285s, black out, Defiant lightbar, triple Hella 100w
    Hi Kev.
    I found you through Joe Gibbons on the FJ Northeasters forum. My FJ has approx. 170K mi on it and had one bearing changed at around 70K. My guess is I should atleast have bearings on hand when one goes I can just replace both.
    The downside is I am in New Brunswick Canada. I was wondering if you could work me up a quote to ship me two bearings to postal code E5N 4L1.
    Really appreciate it.
    Brian
  5. Oct 1, 2015 at 7:51 AM
    #1945
    Sicyota04
    Morgan
    California
    04 DC 4x4
    I have my spindles connected to Camburg UCA's with that Uni ball and that was a bitch to put together. So I am thinking that puller would be easier. What is your opinion?
  6. Oct 1, 2015 at 7:52 AM
    #1946
    nj636
    Kev
    Jersey
    No problem, sending you a PM now.
  7. Oct 1, 2015 at 7:53 AM
    #1947
    nj636
    Kev
    Jersey
    Puller works quite well.
  8. Oct 1, 2015 at 10:52 AM
    #1948
    NBFJCruz
    Brian
    Thanks .
  9. Oct 1, 2015 at 11:05 AM
    #1949
    09Tacomania
    09Tacomania Well-Known Member
    Scott
    Little Rhody
    09 Silver Streak Dbl cab 4x4
    Icon CO's, LR UCA's, Icon rear 2.0 rear resi's, Wheelers 1.5" 3 pk aal, blacked out badges, Andre's devil horn's, Extang tonneau. Oem racks
    Hubs arrived safely. Thanks again. :bananadance:
    nj636[OP] likes this.
  10. Oct 1, 2015 at 12:03 PM
    #1950
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Ok thanks
  11. Oct 1, 2015 at 1:14 PM
    #1951
    easystickerco
    easystickerco Well-Known Member
    San Diego
    Tacoma SR5
    I got my set as well! Looking forward to the weekend :)
    Thanks Kevin!
  12. Oct 2, 2015 at 1:48 AM
    #1952
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Subed, i think that mine are gone. Not sure how to test them, but I think I hear a grinding noise when cruising at around 30 mph.
  13. Oct 2, 2015 at 4:18 AM
    #1953
    nj636
    Kev
    Jersey
    glad they showed up safely :thumbsup:
  14. Oct 2, 2015 at 4:20 AM
    #1954
    nj636
    Kev
    Jersey
    lift the front end of the truck.
    •spin the tire by hand, listen for the grinding noise
    •grab the tire at 12 & 6, push/pull -- any movement in the hub indicates a worn bearing
  15. Oct 2, 2015 at 8:33 AM
    #1955
    tacoholic05
    tacoholic05 Well-Known Member
    05' 4x4
    Hub arrived yesterday and is of good quality - installed in under an hour....Thanks Kev!
    Will drive tonight and see if whine/hum goes away. Loading either side did not change sound and wheels were not loose when checked. Grinding noise only heard when lifted and tire spun.
  16. Oct 2, 2015 at 9:02 AM
    #1956
    easystickerco
    San Diego
    Tacoma SR5
    before, I could hear the noise just driving straight & turning left. Turning right noise went away. When I pullet front tires off, front left was noisy when I spun it. As if bearing was dry. Firestone quoted $900 ea side. I decided to order both fronts. Ones gone, soon the other might go too.
    Put them on last night. Wow! Truck rolls smooth ones again..
    Great quality parts... Thx for making these, it was so easy to replace.
  17. Oct 2, 2015 at 10:19 AM
    #1957
    JIP415
    JIP415 New Member
    JIP
    San Francisco
    Just ordered mine the other day and can't wait! Been rolling around with a bad drivers side hub for way to long. Can't wait to drive around without having to worry about my tire breaking off!
  18. Oct 2, 2015 at 10:36 AM
    #1958
    G.T.
    G.T.
    CONUS
    Ha, this guy had the same shop instructor in high school that I did! We were taught so many "wrong ways" to do stuff back in the 80's.
  19. Oct 2, 2015 at 10:56 AM
    #1959
    nj636
    Kev
    Jersey
    :woot: check back when you drive it :thumbsup:
  20. Oct 2, 2015 at 10:59 AM
    #1960
    nj636
    Kev
    Jersey
    Oofa $900 per side! And I highly doubt they have the SST to remove the nut on the Prerunner hub, which means they can't torque the nut.
    Glad you've got a reliable truck again.
Thread Status:
