Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Apr 2, 2024 at 6:27 PM
    #2061
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  2. Apr 3, 2024 at 2:42 AM
    #2062
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  3. Apr 3, 2024 at 9:23 AM
    #2063
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    I wish they sold the Super Lube o-ring grease locally. I would rather use the grease over lubricant. The grease is a lot more expensive but would probably stay put better.
    I'm wondering if simple silicone grease will work (rated for -40 - +400 degrees). I see a lot of plumbing sections at the big box stores carry silicone grease like the below and states ok for o-rings
    https://www.lowes.com/pd/Danco-0-5-oz-Silicone-Faucet-Grease/1092167
    super_white likes this.
  4. Apr 3, 2024 at 10:16 AM
    #2064
    Danno 1948
    Danno 1948 Danno 1948
    Dan
    Ocala,Fl.
    2023 Tacoma Trail Edition/ Ice White
    little bit of everything
    you have any kits that would work on a 98 4runner 4wd
  5. Apr 3, 2024 at 12:36 PM
    #2065
    05Taco4x4
    2TR-FE Enthusiast
  6. Apr 5, 2024 at 5:48 PM
    #2066
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    Really my reason for joining TW in the first place. Swapped my front wheel bearings/hub assemblies..(passenger was starting to make some sounds) if you don’t have a press or the time to do yourself, this is the way to go.. worked out beautifully for me! Quick and easy, noise is no more.
    Thanks again, would highly recommend supporting this guy @05Taco4x4
  7. Apr 6, 2024 at 7:42 AM
    #2067
    05Taco4x4
    2TR-FE Enthusiast
    Taco5urf likes this.
  8. Apr 8, 2024 at 7:40 AM
    #2068
    T Fades
    Simi Valley, CA
    Installed the new wheel bearing/hub assemblies this weekend.
    A big THANK YOU to @05Taco4x4 for the top notch work and parts. Install went smooth and noise has been eliminated.
    Anybody looking for new hubs/wheel assemblies, look no further and order them here!
  9. Apr 10, 2024 at 11:06 AM
    #2069
    05Taco4x4
    2TR-FE Enthusiast
  10. Apr 11, 2024 at 7:26 PM
    #2070
    05Taco4x4
    2TR-FE Enthusiast
  11. Apr 15, 2024 at 1:03 PM
    #2071
    05Taco4x4
    2TR-FE Enthusiast
  12. Apr 16, 2024 at 3:34 PM
    #2072
    Cal671
    Cal671 Well-Known Member
    calvin
    AZ
    08 Taco smurf, 10 fj, 16 runner
    Pm sent:hattip:
  13. Apr 16, 2024 at 7:13 PM
    #2073
    05Taco4x4
    2TR-FE Enthusiast
    Replied to PM.
  14. Apr 17, 2024 at 7:01 PM
    #2074
    05Taco4x4
    2TR-FE Enthusiast
  15. Apr 22, 2024 at 6:17 PM
    #2075
    05Taco4x4
    2TR-FE Enthusiast
  16. Apr 27, 2024 at 8:56 PM
    #2076
    05Taco4x4
    2TR-FE Enthusiast
  17. Apr 28, 2024 at 6:22 PM
    #2077
    krm11
    krm11 Well-Known Member
    Kyle
    2011 Tacoma Ext Cab Long Bed
    I'll add on to the countless comments already here, if you need new wheel bearings/hubs do yourself a favor and hit up @05Taco4x4 . Got mine installed this weekend and SILENCE, my vibes are gone. I did it with the spare tire bottle jack and some basic hand tools (+torque wrench for axle nut) so if you have the time, don't spend $1k+ to have someone do this.
    FWIW to those considering wheel bearings, my vibe went away when turning left but it was my passenger bearing that was the issue, this seems to be counter to the 'majority' of trends online but not all. Do yourself a favor and just plan to do both. If you get lucky on the first guess, now you've got a spare.
    Thanks again for the great parts and communication!
    05Taco4x4[OP] likes this.
  18. Apr 28, 2024 at 6:39 PM
    #2078
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    They should always be replaced as a pair, if one is bad the other is on its way out.
  19. Apr 28, 2024 at 7:30 PM
    #2079
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    How many miles on your first set?
  20. Apr 28, 2024 at 9:46 PM
    #2080
    krm11
    Kyle
    My best guess is 33k. But to be clear I don't know where the previous hubs came from and I can't speak to the installation at all. It was done at a shop but not a Toyota dealer, from what I can tell on the Carfax.
    The truck currently has 208k on it, I bought it at 195k and started noticing vibes around 200k.
    Carfax Shows 'Wheel bearings/hubs' replaced at 175k. Based on how easy they were to get off (no rust penetrant needed anywhere) I'd say it was the fronts done at 175k.
    Not sure how helpful it is but that's what i've got. I'd expect a lot more than 33k out of this next set though, they seem really solid!
    Green Jeans[QUOTED] likes this.
