Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Apr 29, 2024 at 6:04 PM
    #2081
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  2. Apr 30, 2024 at 6:36 PM
    #2082
    05Taco4x4
    2TR-FE Enthusiast
  3. May 1, 2024 at 7:40 PM
    #2083
    05Taco4x4
    2TR-FE Enthusiast
  4. May 2, 2024 at 9:51 AM
    #2084
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Just a question to those who have installed these themselves, did you replace seals? I watched a couple of videos and none of them mention any seals being replaced. Also is it 35mm axle nut? I seem to recall videos saying it was 36mm.
    “4x4 Install
    Torque CV axle nuts to spec with a calibrated torque wrench.
    A loose assembly shortly after installation means your CV axle nut lost it’s torque.
    If the axle nut loses it's torque, forces acting on the assembly will ruin the bearing.
    Loan-A-Tool
    Torque Wrench (173 lb ft).....
    Socket (35mm)......................
    Puller (if difficult to remove)
    Loctite 241.............................
    Install tips
    Wire brush CV stub splines of rust/grime, wipe and apply anti-seize to splines (not threads)
    After insertion thru hub, clean stub threads with solvent and then apply Loctite 241
    Torque axle nut with wheel on the deck
    Seals:
    Not included
    Knuckle....90316-A0001
    CV............90304-A0001“
  5. May 3, 2024 at 8:13 AM
    #2085
    DriverSound
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Payment sent, PM sent. Thanks
  6. May 4, 2024 at 10:18 AM
    #2086
    05Taco4x4
    2TR-FE Enthusiast
  7. May 4, 2024 at 4:38 PM
    #2087
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
  8. May 5, 2024 at 10:59 AM
    #2088
    05Taco4x4
    2TR-FE Enthusiast
    Replied to PMs
  9. May 6, 2024 at 4:14 PM
    #2089
    05Taco4x4
    2TR-FE Enthusiast
  10. May 11, 2024 at 12:19 PM
    #2090
    05Taco4x4
    2TR-FE Enthusiast
  11. May 14, 2024 at 1:12 PM
    #2091
    216to404
    216to404 Well-Known Member
    2006 RC prerunner
    did you ever get a reply on this? Or have you made the install? Interested as well over here.
  12. May 14, 2024 at 7:03 PM
    #2092
    05Taco4x4
    2TR-FE Enthusiast
  13. May 15, 2024 at 4:43 PM
    #2093
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    PreRunner here.
    Yes the install is really easy, just as Beast describes. You will need to remove the little dust cover from the old hub assemblies (see pic below). I used a deep socket from the inside of the old hub to knock the dust cover off and onto the new hub assemblies. No special tools or new seals needed. I suggest to use a silicone grease on the o-rings prior to install.
    If your rotors are stuck to the hub, spray a little PB Blaster and let it dwell. I also used a bolt (I think was M8x1.25) in the rotor holes to push the rotor away from the hubs.
  14. May 15, 2024 at 6:00 PM
    #2094
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Yes I have installed them and it was as straightforward as I described.
  15. May 15, 2024 at 6:32 PM
    #2095
    216to404
    2006 RC prerunner
    Awesome, thanks all for the response. Instead of saving up for a suspension refresh I might divert funds to a full brake job + these hub assemblies first.
  16. May 19, 2024 at 7:04 PM
    #2096
    05Taco4x4
    2TR-FE Enthusiast
  17. May 22, 2024 at 6:17 PM
    #2097
    05Taco4x4
    2TR-FE Enthusiast
  18. May 24, 2024 at 5:58 PM
    #2098
    05Taco4x4
    2TR-FE Enthusiast
  19. May 25, 2024 at 10:37 AM
    #2099
    05Taco4x4
    2TR-FE Enthusiast
  20. May 25, 2024 at 1:02 PM
    #2100
    TacoTuesday1
    SD CA
    for '11 GX460 fronts
    sent
