Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Jan 11, 2019 at 9:56 AM
    #441
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Agreed, we aren't sending a rocket to Mars...I would have to think that any varation added with the use of a crows foots would be minimal at best.
  2. Jan 11, 2019 at 10:38 AM
    #442
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    It’s based on a force applied at a foot’s distance, so if you’re off to the side at 90 degrees then you’re really close to a foot still and you haven’t changed much distance so you’re absolutely correct.
  3. Jan 11, 2019 at 10:46 AM
    #443
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Have any stuck on hand?
  4. Jan 11, 2019 at 10:47 AM
    #444
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    @Freeheelbillie it depends on the length of your torque wrench. If I assume you use the 2" suggested adapter, a torque setting would be:
    50.5 ft-lbs with a 12" long wrench
    53.1 ft-lbs with a 18" long wrench
    54.5 ft-lbs with a 24" long wrench
    It's not insignificant but not something to overlook. If you find a different adapter, you multiple the desired bolt torque setting by the ratio of the wrench / wrench + adapter.
  5. Jan 11, 2019 at 12:39 PM
    #445
    05Taco4x4
    2TR-FE Enthusiast
    PM sent
  6. Jan 11, 2019 at 1:05 PM
    #446
    VA SOFTACO
    VA SOFTACO ...because who buys hard tacos
    Beauregard
    Virginia Beach, VA
    2015 Tacoma MGM OR DCSB
    Is that dust seal the same for a 2015? Both sides?
  7. Jan 11, 2019 at 1:15 PM
    #447
    05Taco4x4
    2TR-FE Enthusiast
    Yes
  8. Jan 11, 2019 at 1:27 PM
    #448
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Is that the same seal as 90316-A0001? I just pulled my passenger side off and that's the seal on the backside of my spindle where the axle goes in.
  9. Jan 11, 2019 at 1:48 PM
    #449
    05Taco4x4
    2TR-FE Enthusiast
    No, they’re different.
  10. Jan 11, 2019 at 2:17 PM
    #450
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    well crap. So I need to get the 90316-A0001. Will the drivers side be the same seal in the spindle?
  11. Jan 11, 2019 at 3:19 PM
    #451
    05Taco4x4
    2TR-FE Enthusiast
    CV to spindle are different, left to right are the same
  12. Jan 11, 2019 at 6:12 PM
    #452
    VA SOFTACO
    Beauregard
    Virginia Beach, VA
    Yup you lost me with that one. My seal that mounts to the back of the spindle where the axle goes through and then into the hub that was 90316-A0001. Both the driver side and passenger sides will be the same?
  13. Jan 11, 2019 at 6:41 PM
    #453
    05Taco4x4
    2TR-FE Enthusiast
    The seal that goes into the inboard side of the steering knuckle is different than the one on the CV. Each seal on driver's side is the same as driver's side.
  14. Jan 11, 2019 at 6:48 PM
    #454
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Who’s on third base?
    VA SOFTACO and Freeheelbillie like this.
  15. Jan 12, 2019 at 11:10 AM
    #455
    wentz912
    wentz912 Member
    Nic
    09 SWB Tacoma DCSB 6MT
    AFE Intake/Exhaust, Color match Canopy, Tow Package, suspension air bags.
    My google-fu is weak today. Is there an aftermarket substitute for PN 90304A001? Local dealership is three days out on that part and they are $30 each! Already have the passenger side of truck apart and discovered a trashed dust seal, which is probably at least part of why bearing failed.
  16. Jan 12, 2019 at 1:31 PM
    #456
    05Taco4x4
    2TR-FE Enthusiast
    There’s not
  17. Jan 12, 2019 at 1:31 PM
    #457
    05Taco4x4
    2TR-FE Enthusiast
  18. Jan 12, 2019 at 1:37 PM
    #458
    wentz912
    wentz912 Member
    Nic
    I was afraid of that. Ordered the ones local. Looks like she will come apart again next week.
    Also for anybody watching/following along here, don't scoff at the seal driver/puller set. I dicked with the inner seal for nearly an hour with the spindle on the truck. Got it in a minute and a half after renting the driver kit from O'Reilly's.
  19. Jan 16, 2019 at 9:11 AM
    #459
    67 Series IIA
    67 Series IIA Active Member
    Ed
    Green Harbor, MA
    08 4X4
    Bed Tie down's, Heated Mirrors, HD radio, Wet Okley seat covers, Intermittent wipers, side rails, tailgate cap.
    Installed yesterday and I am back in business.
    Truck is running nice and quiet again and as a side benefit the brakes are back to normal as well.
    Thanks again for a quality product and fast delivery.
    05Taco4x4[QUOTED][OP] likes this.
  20. Jan 16, 2019 at 2:48 PM
    #460
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Received mine, they look great and we're packaged well. Bit of grease I presume to prevent rust which is always good.
    Perhaps this is a dumb question, but do I need anything else to make this swap? The speed sensor or anything like that? Or do I just unbolt the old and bolt down the new?
    05Taco4x4[OP] likes this.
