Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Nov 7, 2019 at 8:35 AM
    #861
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  2. Nov 7, 2019 at 9:06 AM
    #862
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Glad I asked, I was about to order 90316-A001. Thanks once again
    05Taco4x4[QUOTED][OP] likes this.
  3. Nov 7, 2019 at 9:09 AM
    #863
    Minimag95
    Minimag95 Well-Known Member
    Niles
    Annapolis, MD
    2009 Pyrite Mica V6 SR5 4x4
    OME's w/ 887 Coils, SPC UCA's, 285 ST Maxx. Mobtown sliders & skid
    That's the PN for the spindle seal
    05Taco4x4[OP] likes this.
  4. Nov 7, 2019 at 6:50 PM
    #864
    orcoastjosh
    orcoastjosh Member
    Ivan
    1996 3.4L V6 4x4
    none
    Thanks anyway!
  5. Nov 8, 2019 at 3:19 AM
    #865
    smkymntn
    smkymntn Active Member
    Adam
    2014 T4R SR5
    Toytec 3" lift, Magnaflow, TRD intake, and lots of little things.
    Can you do a set for 2000 4x4 4cyl?
  6. Nov 9, 2019 at 12:57 PM
    #866
    05Taco4x4
    2TR-FE Enthusiast
    It's a different setup, sorry
  7. Nov 10, 2019 at 11:42 AM
    #867
    plurpimpin
    PDX
    I came to this page for the torque specs and then realized I forgot the dust shield hahaha. Luckily it wasn’t tightened down yet.
  8. Nov 10, 2019 at 2:25 PM
    #868
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Your not the 1st and you won't be the last!
  9. Nov 12, 2019 at 10:38 AM
    #869
    plurpimpin
    PDX
    Got this knocked out this weekend and the biggest struggle for me was pressing the seal into the spindle. I wasted an hour or two trying to do it with the upper ball joint, tie rod end, and sway bar disconnected and tilting the spindle out but it wouldn't cooperate.
    I felt really dumb when I realized it was just 2 more 19mm bolts to pull the whole spindle off. Flat on my garage floor it took all of 30 seconds to press the new seal in. HIGHLY recommend pulling the spindle to do the seal. I couldn't get it in straight otherwise.
    EDIT: I forgot to mention the truck rides WAY better and is so much quieter. On top of the vibrations I was feeling through the floorboard it got rid of a steering wheel wobble that I had assumed was an alignment issue (turned out it was the wheel bearing). Now my truck is super smooth going down the highway like it was when new!
  10. Nov 12, 2019 at 4:55 PM
    #870
    05Taco4x4
    2TR-FE Enthusiast
    That's awesome :cheers:
  11. Nov 12, 2019 at 5:33 PM
    #871
    05Taco4x4
    2TR-FE Enthusiast
  12. Nov 13, 2019 at 8:45 PM
    #872
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    subbed, I'm in the process of figuring out if it's my wheel bearing or not. Sounds like tire noise- but I swapped out with a friend and it's still making the humming sound. This replacement assembly looks like substantially less work, than pulling everything apart and possibly screw up pressing the bearing in myself.
  13. Nov 13, 2019 at 10:48 PM
    #873
    plurpimpin
    PDX
    I was trying to track down a mystery noise too. Figured out it was the wheel bearing by jacking the front wheels up and pushing on them at the 12 and 6 o’clock positions to see if there was any side to side play. If it wobbles it’s the wheel bearing for sure.
    Mudman[QUOTED] and 05Taco4x4[OP] like this.
  14. Nov 14, 2019 at 2:29 PM
    #874
    Mudman
    Cerritos
    08 4X4 TRD Sport
    Looks like that was the trick. I tried it yesterday, but after a drive and had very little play. So I wasn't sure if that was it, maybe the bearing was warm and tightened things up.
    Did the same today while cold, noticeably different. @05Taco4x4, you'll be getting an order from me hopefully in the very near future.
    Shot a short video, can someone confirm for me if it's super bad? Or could I go a little bit while I save up?
    https://youtu.be/SRqq2aVKzCI
  15. Nov 14, 2019 at 2:49 PM
    #875
    plurpimpin
    PDX
    That’s pretty worn. Mine didn’t move quite that much but I can’t speak for how drivable it is or isn’t. I feel like it’s a hard thing to judge so I played it safe and borrowed my girlfriends car for a few days until I could fix it. This was my first wheel bearing job so someone with more experience might be able to chime in.
    Mudman[QUOTED] likes this.
  16. Nov 14, 2019 at 2:53 PM
    #876
    Mudman
    Cerritos
    08 4X4 TRD Sport
    I definitely want to replace it asap, just not in the budget right now.
  17. Nov 14, 2019 at 5:43 PM
    #877
    abqnurse80
    abqnurse80 Well-Known Member
    Nic
    ABQ, NM
    2012 FJ Cruiser
    Bilstein 5100 all around, first clip front. AVS window visors, BFG AT KO2s. JBL.
    Got mine today, look amazing, never have seen such a great packing job!!! Thanks @05Taco4x4!!! Can't wait to get them on!!!
  18. Nov 15, 2019 at 6:34 AM
    #878
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    That's about the worst that I've seen. I highly recommend that you adjust your budget and put something else on hold.
  19. Nov 15, 2019 at 8:21 AM
    #879
    05Taco4x4
    2TR-FE Enthusiast
    Awesome, glad they arrived safely
    mcharfauros likes this.
  20. Nov 15, 2019 at 12:57 PM
    #880
    Mudman
    Cerritos
    08 4X4 TRD Sport
    ordering now. This is my first time issue with any bearings, I haven't had friends with the problem on their cars. So it was hard for me to gauge how bad it really was. Glad I shot the video. Thanks for the suggestion.
