Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Nov 27, 2019 at 8:52 PM
    #901
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    National NSK supply has run dry again, until January :confused:
  2. Nov 28, 2019 at 7:13 PM
    #902
    05Taco4x4
    2TR-FE Enthusiast
    Bearing Friday
    All orders placed and paid between now and 7pm est tomorrow receive an additional $10 off already marked down prices!
  3. Nov 29, 2019 at 1:11 PM
    #903
    mgw24
    mgw24 Well-Known Member
    Central Idaho
    2011 DCLB 4WD SR5, 1998 Reg cab 5 lug
    Crappy spacer lift w/AAL, Camburg Balljoint UCAs, Pioneer AVH-X2700BS
    Easy diy job. It took me about 2 and a half hours total. Had no issues getting things apart after a few taps with a rubber mallet. I didn’t replace the knuckle seal, they both looked to be in good condition after cleaning them up. Both bearings were bad, but the drivers side was much worse than the passenger side. Noticeable difference, vibration and noise is gone!
    Great service, thanks!
  4. Dec 2, 2019 at 10:34 PM
    #904
    Mudman
    Mudman Well-Known Member
    Cerritos
    08 4X4 TRD Sport
    Dumb question, but for those that replaced their cv to knuckle seals while doing this swap- did you guys add any grease between the two?
    I noticed the original knuckle/cv seals had a bead of grease around them- none of which seemed to do anything. Although, it just occurred to me, that it's probably not supposed to be bone dry?
  5. Dec 3, 2019 at 2:46 PM
    #905
    05Taco4x4
    2TR-FE Enthusiast
  6. Dec 5, 2019 at 11:49 AM
    #906
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    I need just one if you can help me out. I did the passenger last year, should have just done them both! Driver's side is on the way out. Will send you a PM.
    Carl
  7. Dec 5, 2019 at 12:05 PM
    #907
    05Taco4x4
    2TR-FE Enthusiast
  8. Dec 5, 2019 at 12:08 PM
    #908
    05Taco4x4
    2TR-FE Enthusiast
    Replied
  9. Dec 7, 2019 at 5:54 PM
    #909
    05Taco4x4
    2TR-FE Enthusiast
    vtown and mcharfauros like this.
  10. Dec 9, 2019 at 2:29 PM
    #910
    05Taco4x4
    2TR-FE Enthusiast
  11. Dec 11, 2019 at 4:16 PM
    #911
    vtown
    CT
    Received!
    Thats some serious packaging, it took tools to extract
    I appreciate your speed and diligence!
    Thanks again!
    05Taco4x4[OP] likes this.
  12. Dec 14, 2019 at 11:32 AM
    #912
    05Taco4x4
    2TR-FE Enthusiast
  13. Dec 15, 2019 at 7:39 PM
    #913
    KevinG
    KevinG Active Member
    Kevin
    Chandler, AZ
    2010 TRD Offroad Double Cab
    I received mine on Friday. Thank you for the great service!
    mcharfauros and 05Taco4x4[OP] like this.
  14. Dec 17, 2019 at 7:20 AM
    #914
    05Taco4x4
    2TR-FE Enthusiast
  15. Dec 19, 2019 at 7:33 PM
    #915
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    Sub’d for when I need these
  16. Dec 23, 2019 at 7:10 AM
    #916
    05Taco4x4
    2TR-FE Enthusiast
  17. Dec 27, 2019 at 7:17 AM
    #917
    05Taco4x4
    2TR-FE Enthusiast
  18. Dec 28, 2019 at 5:53 AM
    #918
    05Taco4x4
    2TR-FE Enthusiast
  19. Dec 28, 2019 at 12:13 PM
    #919
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    05Taco4x4[QUOTED][OP] likes this.
  20. Dec 28, 2019 at 12:40 PM
    #920
    kingk0ng
    kingk0ng Well-Known Member
    11 TRD OR AC
    just a few things.
    Hub comes with oring and seal? Or is that separate for 4wd.
