Wheel Bearings & Hubs Press Service *** OE NSK ***
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Mar 4, 2018.
  1. Dec 26, 2020 at 1:36 PM
    #1401
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    @05Taco4x4 Received my wheel bearing/hub ASSY. today! I must say, I worked in logistics for 10 years and your packaging is absolutely amazing! Only demerit is the packaging is not reusable! :thumbsup::rofl:
    05Taco4x4[OP] likes this.
  2. Jan 1, 2021 at 10:56 AM
    #1402
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Finally installed both last night and today. Right side axle nut put up a damn good fight, left side took a quarter of the amount of time.
    AMAZING the lack of noise difference!! Definitely should have done this sooner!!
  3. Jan 1, 2021 at 3:25 PM
    #1403
    SparkyIX
    SparkyIX Well-Known Member
    Anthony
    Tonopah, AZ
    2009 TM 4x4 DCSB 6-Speed Swap
    PM sent
  4. Jan 1, 2021 at 6:50 PM
    #1404
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Replied
  5. Jan 3, 2021 at 2:56 PM
    #1405
    WHITEW0LFE
    WHITEW0LFE Member
    2007 FJ Cruiser
    PM sent. I wanted to confirm the payment details again since I first sent you a message back in October.
    I am ready to order.
  6. Jan 3, 2021 at 4:26 PM
    #1406
    05Taco4x4
    2TR-FE Enthusiast
    Replied to PM
  7. Jan 4, 2021 at 1:54 AM
    #1407
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    I might be ordering a set from you. I have to determine if its my AT tires or the hub. I have 120k on the truck and thinking it’s probably a smart maintenance job to do them soon
  8. Jan 4, 2021 at 4:03 AM
    #1408
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I just did mine, replacing the original at 146K and I truly thought the noise was tire created. Damn truck is near silent now.
  9. Jan 4, 2021 at 5:02 AM
    #1409
    05Taco4x4
    2TR-FE Enthusiast
    Same here, purchased my truck with ~70K and always thought was the tires to only find out later it was the bearings
    EdinCincinnati likes this.
  10. Jan 5, 2021 at 12:44 PM
    #1410
    05Taco4x4
    2TR-FE Enthusiast
  11. Jan 6, 2021 at 7:21 AM
    #1411
    05Taco4x4
    2TR-FE Enthusiast
  12. Jan 7, 2021 at 11:36 AM
    #1412
    WHITEW0LFE
    WHITEW0LFE Member
    2007 FJ Cruiser
    This will be my first time replacing mine on my 2007 FJ Cruiser and this has me a little confused as I learn by doing generally. Is it 2 seals per side, or just one per side? Your first sentence makes it seem like there are 2 per side. I may just be comprehending it wrong.
    In my attached illustration its #10. It also looks like #5 is the same thing. So 2 per side and they are the same part number?
    Is it better to get them from Toyota or is a place like Oreillys ok for seals?
    Any help appreciated.
  13. Jan 7, 2021 at 1:00 PM
    #1413
    TACOMA2NDGEN
    ROLAND
    new jersey
    baja squadron pros
    So I finally checked my hubs. I jacked up the truck and the passenger side definitely has a little play when i shake the wheel and when i spin it i hear the noise. Driver side just the noise no play. Can anyone confirm the nut size on a 2010 is it 35mm or 36?
  14. Jan 7, 2021 at 2:29 PM
    #1414
    WHITEW0LFE
    WHITEW0LFE Member
    2007 FJ Cruiser
    From 05Taco4x4s first post......
    I would assume its the same, so you may want to wait for confirmation as assuming can mess stuff up. lol
  15. Jan 7, 2021 at 2:32 PM
    #1415
    05Taco4x4
    2TR-FE Enthusiast
  16. Jan 7, 2021 at 3:46 PM
    #1416
    05Taco4x4
    2TR-FE Enthusiast
    5 and 10 are different, 5 is part of the bearing assembly. 10 is inboard side of the steering knuckle and one of the two I reference, the other I reference mates with 10 and is on the end of the CV joint.
  17. Jan 7, 2021 at 7:03 PM
    #1417
    SparkyIX
    Anthony
    Tonopah, AZ
    Hubs came a day early and safe. Thanks again! Good luck with your manual to auto swap also.
  18. Jan 8, 2021 at 6:13 AM
    #1418
    05Taco4x4
    2TR-FE Enthusiast
    Right on, thanks.
  19. Jan 9, 2021 at 9:13 AM
    #1419
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  20. Jan 10, 2021 at 8:39 PM
    #1420
    caribe makaira
    Caribbean, Puerto Rico
    All is good. Wheel nuts went on without any problems. I too thought the tires were the noise culprit.
    Thank you oh mighty Gazoo :thumbsup:
    05Taco4x4[OP] and Muddinfun like this.
