wheel help
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaDude01, Jun 15, 2010.
  1. Jun 18, 2010 at 7:17 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    ProComp 8069's FTW!!!! :)
  2. Jun 18, 2010 at 7:34 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    so if he's running 16x7 4.5"bs, and he puts the same tires on 16x8 4.0"bs, each tire wont be 1.5" further out?
    because that's pretty much what I just said.
  3. Jun 18, 2010 at 7:42 AM
    YotaDude01
    YotaDude01 [OP] Kentucky Boy
    KY
    01' TRD off-road
    Alexander do you have a lift on your truck
  4. Jun 18, 2010 at 9:29 AM
    YotaDude01
    KY
    01' TRD off-road
    if i do get the 16x8 wheels will i have to get a lift so they wont rub?
  5. Jun 18, 2010 at 11:07 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What size tire?
  6. Jun 20, 2010 at 5:19 PM
    AlexanderD
    AlexanderD Well-Known Member
    Alex
    whitby Ontario
    03' tacoma 4x4 trd step-side
    no lift as of yet. and lots of sag actually too. haha anyhow. rubbing is more up to the tire size i think then anything. i have 31' x 10.50 r15 with the 3.75 back spacing and they only the slightest bit if turning and hitting a bump.
    as far as i have read on here, if you run the 16" rim you can get away with 265 75 r16's at most with stock suspension.
  7. Jun 20, 2010 at 5:32 PM
    AlexanderD
    Alex
    whitby Ontario
    i was just trying to be clear as he doesn't know what tires he will be running.
    if he goes with the 16x8 with the 4" b/s the outside of his rim will be pushed out by 1.5". then the extra width from what ever over sized tires he chooses.
    say he gets a 10.50 that would add another 1.25" on to the width making the total 2.75" ya? i think that math is right
  8. Jun 21, 2010 at 4:32 AM
    YotaDude01
    KY
    01' TRD off-road
    thanks guys. when i get some wheels ill post some pics on here.
  9. Jun 22, 2010 at 10:52 PM
    pittim
    Pennsyltucky
    Boujee Prius
    if he's running stock wheels and size tires, he has 265s (which is about 10.5" wide) on a 16x7 4.5" bs rim.
    if he runs 10.5" wide tires on a 16x8 4.0"bs rim, the outside of the tire will be 1.5" further out since the tire width doesnt change.
    if he goes 12.5" wide tires, add an extra inch to the width.
  10. Jun 23, 2010 at 4:45 AM
    AlexanderD
    Alex
    whitby Ontario
    my bad. as long as he has and stays with stock width tires what you said is surly right. i was thinking of the tires my truck came with(235's) and i didn't even account for the width going out either side of the rim. cheers.
    AlexanderD
  11. Jul 19, 2010 at 9:35 AM
    YotaDude01
    KY
    01' TRD off-road
    I got to get new tires before i can afford wheels. So my question is if i get the stock tires 265-70-16 on a 16x7 wheel. Will the same tires fit a 16x8 wheel?
  12. Jul 19, 2010 at 10:55 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, you can run that size tire on either a 7" or 8" wide rim.
  13. Jul 19, 2010 at 2:16 PM
    YotaDude01
    KY
    01' TRD off-road
    Thanks. I would hate to buy that size tire then them not fit right on a 8 inch wheel.
  14. Jul 20, 2010 at 4:37 AM
    YotaDude01
    KY
    01' TRD off-road
    can anyone else confirm that they will fit?
