Wheel Hub Assembly Suppliers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by MissingRedstone, Aug 5, 2020.
  1. Aug 12, 2020 at 10:38 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Hahaha true... i have it and i hate it, I try to forget about it all the time. I don't know about the GM ones but I know I hated fords "automatic" hubs that were on my Bronco II, they like to disengage when you roll backwards in reverse so you'd lose front wheel drive at the WORST times!
    0xDEADBEEF[QUOTED] likes this.
  2. Aug 12, 2020 at 5:16 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I need to do this also. My drivers side rear wheel bearing went on me last month and I figure at 188k the fronts are due.
    also Harbor freight has a press for short money.
  3. Aug 13, 2020 at 7:51 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    That press will do the rears but won’t come close to handling the front bearings. You’ll want a 20T minimum for the fronts.
    QMEDJoe[QUOTED] likes this.
  4. Aug 13, 2020 at 8:22 AM
    penadam
    penadam Well-Known Member
    Denver
    2003 Double Cab Tacoma TRD
    If you go the at home press route, don't forget to budget for press sleeves and additional plates or fixtures.
  5. Aug 13, 2020 at 8:24 AM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    And a blast shield! when that bearing was starting to move it made horrifying sounds. I tucked my tail and hid behind the tire machine while cranking the handle.
    cruxofthebisquit likes this.
  6. Aug 13, 2020 at 8:46 AM
    QMEDJoe
    Joe
    Thanks, Good to know. :thumbsup:
  7. Aug 14, 2020 at 2:23 PM
    petecarlson
    petecarlson Well-Known Member
    2002 4X4 DC TRD
    Coupon for the 20 ton $149.99 at HF through the end of the month:
  8. Aug 14, 2020 at 3:52 PM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    Watch Timmy the Toolman's videos on youtube if haven't already. It will give you an idea of what you need for this job. It's a pita of a job but doable. I just ended up buying the parts & taking the steering knuckle to a machine shop to do the press work.
  9. Sep 2, 2020 at 5:39 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    I was about to ask on this topic well now I know I need bearing and seals but do I need the hubs also? or that’s just easier job I will take everything to a shop to get then swap.
  10. Sep 3, 2020 at 5:08 PM
    TeeYoda
    PNW
    You shouldn't need new hubs unless the people doing the job damage the originals. If I remember correctly, besides the bearing & seals, there is also a spacer ring in there that you might need if the old one gets damaged during the process of removing the old bearing, which happened to me.
  11. Sep 3, 2020 at 6:05 PM
    taco03Trd
    Carlos
    Riverside ca
    Ok thanks for the info . Gonna need inner tie rods too :eek::spending:
