wheel offset and backspacing
Discussion in '1st Gen. Tacomas (1995-2004)' started by bill-e-boy, Jul 20, 2010.
  1. Jul 20, 2010 at 2:38 PM
    bill-e-boy
    bill-e-boy [OP] new and improved
    billy
    florence
    04 dbl cab lifted pre-Runner
    added factory roof rack, factory skid plate, removed cheesy running boards, built a pvc bike rack, added interior floor lighting, added decal plate under rear window, added sylvania silverstars, installed toytec ultimate 3" lift, added hella optilux yellow fog lights, added orange park lights to the turn signals, new 265/75/16 goodyear duratracs tires and raceline rockcrusher 16" wheels
    questions about offset and backspacing,
    I have an 04 dbl cab. I’ve lifted it with toytec ultimate lift coilovers and add-a-leaf.
    My stock wheel is 16 x 8 with 4.5” of backspacing and I have 1.5” all-pro spacers all the way around.
    I'm not an off-roader...truck stays on roads 99% of the time. I lifted it and added spacers cause I like the way it looks.
    I really like the factory wheel and the wider stance.
    But, I have a bit of steering wheel vibration, I’ve read the spacers may cause that.
    Question 1 - So if I bought a new set of wheels, cccould this solve the vibration problem?
    Question 2 - Does this mean that right now I actually have 3” of backspacing?
    Question 3 - Is there a possibility that a 1” spacer would give me less vibration?
    Question 4 - To keep my stance the same, I would need a wheel with 3” of backspacing?
    Question 5 - give me suggestions/opinions....what is the ideal wheel backspacing for a 16 x 8 wheel to put the tire/wheel out flush with the fender flare?...is it 16 x 8 wheel with 4" of bs or 3.5" maybe?
  2. Jul 20, 2010 at 2:41 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    im not 100% but i recall the factory wheels (alloys) being 16x7 not 16x8. I put on 16x8 moto metal 951's with a 4.5 in backspace and they stick out more than the stock wheels. Im not sure about your vibration problem. My advice is get rid of the wheel spacers, buy some 16x8 wheels, and some wider tires (285). :)
  3. Jul 20, 2010 at 2:49 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    when i had stock wheels (16x7) with spacers (1.25") i liked the way they stuck out.
    My new wheels without spacers stick out a little less but very close. They are 16x8 with 4"bs.
    Dont worry about the vibration. Since youre getting new wheels see if the vibration goes away after you install them.
  4. Jul 20, 2010 at 3:17 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    try 16x8s with 4" backspace... you can also get into some 16x8s with 3.625" backspace if you want them to stick out a bit more...
    only wheels that you can typically get in 2.5" or 3" backspace are black steel rock crawler wheels but in 15s...
    alloys would be lighter
  5. Jul 20, 2010 at 7:04 PM
    bill-e-boy
    billy
    florence
    I'd really like to keep my factory "look"...I really like the factory wheels and the way it looks with spacers.....but from what I read, people ditch the spacers and get new wheels.
    anybody have a 1" or 1.25" spacer on the factory wheel/same kind of setup?...do you get vibration with your spacers?
  6. Jul 20, 2010 at 7:39 PM
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    i have my stock wheels and 1.25 spidertrax wheel spacers. my first suggestion would be to check all your spacers and make sure they are tight! 70-80 ft lbs i believe is what mine are set too. second balance your tires makes a huge difference i noticed slight vibs before my truck was balanced and aligned, now the only vibs i'm feeling are from my drive shaft the odd time due to its angle being off from my lift. for your steering i belive that wheelers has a steering column bushings kit. not to expensive and might help.
  7. Jul 20, 2010 at 7:46 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    new wheels sounds easier to deal with... haha
  8. Jul 20, 2010 at 9:37 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    1) Doubtful. Get your tires road force balanced and your truck aligned.
    2) Technically no. Backspacing is the measurement from the mounting surface of the wheel to the inside edge of the wheel. It's still 4.5". But, with the 1.5" spacer, your setup appears to be the same as a wheel with 3" BS.
    3) See 1.
    4) See 2
    5) 16x8 with 4" BS seems to be pretty much in line with the fenders.
