wheel offset
Discussion in 'Wheels & Tires' started by zcolson, Dec 19, 2006.
  1. Dec 19, 2006 at 5:21 PM
    zcolson
    zcolson [OP] Member
    Northville New York
    02 tacoma singlecab
    3" toytec lift 3" tires
    how would you get the offset for your rim?
  2. Dec 20, 2006 at 7:30 PM
    pb2themax
    pb2themax Mod Master
    TRD Sport 4x4
    Do you mean how do you figure the offset of the stock wheel? Or how would you figure the offset for an aftermarket wheel?
    You should probably check the wheel/tire forum.
  3. Jan 4, 2007 at 6:22 PM
    zcolson
    zcolson [OP] Member
    Northville New York
    02 tacoma singlecab
    im talking about an aftermarket rim. what would be a safe offset to use on my tacoma? because im going to order a set of aftermarket rims and i want to put a wider tire on my truck and not have it rub.
  4. Jan 4, 2007 at 6:26 PM
    zcolson
    zcolson [OP] Member
    Northville New York
    02 tacoma singlecab
    im looking to have a 33x11.5r15
  5. Jan 4, 2007 at 6:36 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
  6. Jan 4, 2007 at 7:03 PM
    pb2themax
    TRD Sport 4x4
    4.5" of backspacing is pretty much perfect for a 3" lifted 05+ Tacoma. That's what I have on my truck. This will also help you fit wider tires without rubbing the upper control arm. I think the stock wheels are 5" of backspacing. The less backspacing, the further out the rim will be away from the hub.
    Toynado likes this.
  7. Jan 5, 2007 at 5:36 PM
    zcolson
    zcolson [OP] Member
    Northville New York
    02 tacoma singlecab
    i have an 02 will that rim also work on my truck?
  8. May 18, 2008 at 5:45 PM
    05blacktaco
    05blacktaco Member
    WV
    05 Black 4cyl 5-spd
    3" Tough Country Lift, 285/75/R16 General Grabber At2 on SSC Performance Chrome Wheels and a Dual Exhaust
    I have a 2005, i am looking to put 2003 4runner wheels on it for winter. Can i put these on it and what kind of backspacing should i look for?
  9. May 26, 2008 at 2:02 PM
    jayheath2002
    jayheath2002 Active Member
    Parkville, MD
    2001 Tacoma SR5 4X4
    2 1/2" Lift, 285/75/16 BFG Mud Terrain
    I lifted my 2001 Tacoma 2 1/2" and put on 285/75/16 (33.1X11.3") BFG Mud-Terrains. The tires rub the upper control arm when the suspension is extended. I want to go to 8" steel rims instead of the factory 7" rims. What backspacing should I have so the tires don't rub the upper control arm or stick out so far they rub the pinch weld or front bumper when turning?
