wheel problem
Discussion in 'Wheels & Tires' started by 05bcrowl, Feb 19, 2012.
  1. Feb 19, 2012 at 6:39 PM
    05bcrowl
    05bcrowl [OP] Member
    i have a 2007 access cab....stock ride height....bought a set of new 18x9 XD Monsters with 265/60/18 michelins from a local guy.....i was told the rims were -12mm offset which would be a 4.5" BS.....well i just got around to putting them on my truck and decided to measure them real quick.....found out its actually a 6.38" BS with a +35mm offset.....how screwed am i?
  2. Feb 20, 2012 at 6:09 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Very. There's no way they will fit.
  3. Feb 20, 2012 at 11:02 AM
    05bcrowl
    well I took them to a shop n had them mount em up to see if spacers would even work....they mounted up just fine n still had about .25" of clearance
  4. Feb 20, 2012 at 11:10 AM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    07 4dr 4x4 V6
    Fog Light Mod
    owned:D
  5. Feb 20, 2012 at 11:14 AM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 3" with 885s and top plate spacer, 2" AAL, OME rear shocks, Light Racing/SPC UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    :rofl:
  6. Feb 20, 2012 at 1:27 PM
    KPT
    09 Prerunner
    Did they put the truck back the ground, and did you turn the wheel to full lock?
  7. Feb 20, 2012 at 5:44 PM
    05bcrowl
    Yup and drove it the 36miles to work....no rubbing at all....
  8. Feb 20, 2012 at 5:52 PM
    KPT
    09 Prerunner
    I don't see how it's possible because I have 5.4" bs, 18x9 wheels and I sure don't have 1" to spare between the tire and uca. I'd just keep an eye on it.
  9. Feb 20, 2012 at 6:36 PM
    05bcrowl
    Well idk....but from feeling with my hand it's about the same clearance as my stock 17x7.5 with 265/65/17
