wheel sensor question?
Discussion in 'Wheels & Tires' started by padoos1, Apr 20, 2009.
  1. Apr 20, 2009 at 3:48 PM
    padoos1
    padoos1 [OP] Well-Known Member
    biloxi
    2009 tacoma d/c 4x4
    are the tire pressure sensors diffrent for the steel wheels than the ones on the aluminum wheels?
  2. Apr 20, 2009 at 4:01 PM
    Southernsurfer
    Southernsurfer Well-Known Member
    FL
    2007 DC LB 4X4 TRD Sport
    Bilstein 5100 Rears & Fronts @ 1.75 / TSB 4 Leaf Pak / TRD FJ SE Anthracite wheels w/ BFG AT KO's 265/75/16 / Satoshi Grille w/Hella 500's / Blacked Out headlights / OEM LED Tail lights / 15% Llumar Tint De-Badged / OEM Front Skid Plate / Vinyl/Leather arm-rest mod / Weather Tech mats / TRD seat covers / Tacoma LB Bed mat / Door sill protectors / OEM Class IV Hitch / JL 500/1 w/2 JL 10" Subs / JL Audio Frnt & Rear speakers / Alpine IVA-W505 w/Bypass
    From what I have read , Yes they are
  3. Apr 20, 2009 at 4:06 PM
    padoos1
    biloxi
    2009 tacoma d/c 4x4
    would you happen to know where i could check part #s. ,the sensors that i have look like the ones i see for the alloy wheels, they have the 20 degree angle and the part # is paxpmv108j. any ideas?
  4. Apr 20, 2009 at 4:42 PM
    TRDnAZ
    TRDnAZ Well-Known Member
    Chandler, Arizona
    Desert Sand Mica
    Found this on another forum but no part numbers. "Two types of sensors for Toyota, one with a 20 degree angle used for the steel wheels and one with a 40 degree angle for the aluminum wheels."
    Hope this help's.
  5. Apr 20, 2009 at 5:07 PM
    padoos1
    biloxi
    2009 tacoma d/c 4x4
    thanks man
  6. Apr 21, 2009 at 2:34 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    I had mine switched from steel wheels to alloy wheels with no problems. I've heard they are different, but they fit by being mounted differently :confused:....I don't know exactly, but the ones from steel wheels do in fact work on some alloy wheels.
  7. Apr 21, 2009 at 7:02 AM
    TRDnAZ
    Chandler, Arizona
    Desert Sand Mica
    Opp's apparently the person i quoted above has it backwards. The 20 degree angle sensors are used in the TRD alloy wheels and the 40 degress in the "steel" wheels.
    Also here's what I found for the part numbers.
    Toyota TPMS Sensor 42607-06011, 42607-33021 & 42607-33011 for 2006 – 2009 Tacoma w/Off-Road or Sport package (TRD alloy wheels)
    Frequency : 315 MHZ
    Color : Black
    Valve stem angle: 20 Degree
    As for the "steel" wheel sensor part number. i just can't seem to find it.
  8. Apr 21, 2009 at 2:07 PM
    padoos1
    biloxi
    2009 tacoma d/c 4x4
    the above post was correct the sensors off the steel wheels will in fact work on the alloy wheels, all you have to do is turn the angle a little.
  9. Apr 21, 2009 at 2:08 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    good luck doing that without breaking the POS
