wheel set up
Discussion in 'Wheels & Tires' started by manofsteel, Mar 18, 2013.
  1. Mar 18, 2013 at 3:52 PM
    manofsteel
    manofsteel [OP] Active Member
    Texas
    TRD Off Road
    about to pull the trigger on these but wanted to make sure they will fit.
    My truck set up - 5100's up front set at 1.75 and tsb for rear.
    Tires will be BFG all-terrains - 275 65.
    Thoughts? Should I have any problems?
    Thanks in advance.
    BMF Wheels
    NOVAKANE, 18x9 with 6 on 5.5 Bolt Pattern - Stealth
    • Wheel Size: 18x9
    • 6 on 5.5 Bolt Pattern
    • Offset: 0
    • Backspace: 5
    • Max Load:
    • Finish: Stealth
  2. Mar 19, 2013 at 5:45 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Yes, they will fit (as long as the hub bore is 106mm or larger). You'll need to trim a bit of the black fenderwell plastic though.
  3. Mar 21, 2013 at 7:26 PM
    manofsteel
    Texas
    TRD Off Road
    well ordered the wheels but they are on back order, BMF stated they are being made right now.... playing the waiting game now
  4. Apr 11, 2013 at 11:19 AM
    JRod4928
    JRod4928 Well-Known Member
    Pittsburgh
    '12 Tacoma SR5
    Extang Trifecta Tonneau WeatherTech Floor Liners Pop & Lock Tailgate Lock Antenna X Black Mesh Grillcraft with Tacoma Badge (Upper) and Cross (Lower) 18" BMF Wheels / Cooper 31.5" Tires 2" Leveling Kit
    see if you can get ahold of 'Lundy' on these forums, he cut me a pretty good deal on these wheels, he works for a BMF wheel distributor. He might be able to get them to you faster than 4wheelparts, for a better price.
    I run 265/65's and had slight rubbing on the front. I'm sure 275 will have more problems.
  5. Apr 13, 2013 at 10:41 AM
    manofsteel
    Texas
    TRD Off Road
    I ordered through discount tire. Talked to BMF during the week and they are waiting on wheels to be made. So not sure when they are coming in.
    Jrod what lift are you using? Just curious on rubbing I might encounter.
    Thx
  6. Apr 13, 2013 at 11:07 AM
    liferider
    liferider Active Member
    Vancouver WA
    2011 Tacoma 4x4
  7. Apr 15, 2013 at 12:33 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    It's a 2" front spacer lift. No lift to the back. If you use bilstein's or OME in the front to lift it 1.75" - 2", the effect is still the same and you may have the same issue, but it all depends on your wheel backspacing and tire width/height. That's what causes the rubbing in this case - not the lift.
  8. Apr 15, 2013 at 12:34 PM
    JRod4928
    Pittsburgh
    '12 Tacoma SR5
    your alignment numbers have an affect as well. One side of mine rubbed more than the other, and it corresponded to the amount of caster that they got out of the alignment.
    Lifting it 2" is the perfect amount IMO, because they got the alignment back in spec without UCAs, and it changes the look of the truck a lot.
  9. Apr 15, 2013 at 2:17 PM
    manofsteel
    Texas
    TRD Off Road
    cool thx.
