Wheel size and offset for 33's on 08 Taco?
Discussion in 'Wheels & Tires' started by DJ_Taco, Nov 11, 2008.
  1. Nov 11, 2008 at 8:41 AM
    DJ_Taco
    DJ_Taco [OP] Member
    Ga
    08 TRD Off Road
    I am putting a 3" Lift on my 08 Taco Off Road and want to go put a little larger tires on as well.
    I am looking at Mickey Thompson ATZ 285/75R16 or 285/70R17.
    Which wheel size with what offset do I need to aviod any trimming?
  2. Nov 13, 2008 at 11:38 AM
    DJ_Taco
    DJ_Taco [OP] Member
    Ga
    08 TRD Off Road
    Well I didnt receive any repies so I called 4wheelparts and the rep said, To avoid any rubbing/trimming I should go with an 17x9 BS 4.5 OS -12 or more.
    That being said, I ordered my wheels and tires (285/70R17). They will be at my house when I get home from Iraq. YAY!!:D
  3. Nov 13, 2008 at 11:46 AM
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    Hey DJ, missed your post, but that's a good size to go with. I have the Dick Cepek DC-1 at 17x9, 4.5, -12 also. My tires are 285/70/17 Nittos. I have some rubbing going on ever since I had my Total Chaos UPCs installed, so I have to trim more of the front mudflaps.
    Good choices!
  4. Nov 13, 2008 at 5:45 PM
    DJ_Taco
    DJ_Taco [OP] Member
    Ga
    08 TRD Off Road
    Banchi,
    Did you have any rubbing prior to the new upc's?
    If so, do you think wheel spacers would prevent that?
    How much do your tires stick out past the fender well?
    I considered installling wheel spacers to get more tire outside the fender well considering it isnt already the amount I would like. Would this cause any rubbing/clearance issues in any other locations?
    DJ
  5. Nov 16, 2008 at 3:45 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Hey I am in the same boat as you are. I am also going to get a 3 inch leveling kit for my Taco but I have 18x9 inch rims with a -12 offset. I am thinking about getting some 285/65/18's on them because some other Taco guys are sporting those with the same size rims I have. Now I just need to get it lifted and see if I am going to have to do any trimming up or not. Let me know once you get yours all set up if you had to do any trimming. Thanks!!!
  6. Nov 16, 2008 at 3:46 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Oh and hey, look at out membership numbers! I joined up right after you did!! HAHAHA!!! Nice!!!
