wheel spacer for 2001 tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by keeganfl, Aug 6, 2010.
  1. Aug 6, 2010 at 7:02 PM
    keeganfl
    keeganfl [OP] Well-Known Member
    Keegan
    Martin County,FL
    2001 SR5 Prerunner,5 inch lift
    offroad fog and lights,pa,rough country suspension kit 2.5 inches,and leveling kit in the front.bilstein 5100,4X 150 watt lights
    pro's and con's for 2wd prerunner
  2. Aug 6, 2010 at 9:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If there is no other way, do it. If there are other choices, think again.
  3. Aug 6, 2010 at 9:34 PM
    Tacorunner87
    Tacorunner87 Well-Known Member
    Chino Hills Ca
    To much to list!
