Wheel Spacer ?
Discussion in 'Wheels & Tires' started by Fox2011PM, Jul 27, 2012.
  1. Jul 27, 2012 at 3:03 PM
    Fox2011PM
    Fox2011PM [OP] "The Mountains are calling"
    '13 DCSB 4X4 TRD OR
    ADS 2.5" CO's w/adj, ADS 2.5" Rears w/ piggybacks, Firestone air bags and 1.5" AAL, SCS SR8s, Tom Woods custom one piece drive shaft....more to come
    Wanting to purchase some spidertrax wheel spacers. I currently have the stock 265/70/16's that I am planning on running til they wear out then moving to a 265/75/16. Will the spacer's work with both of these tire specs with no rubbing issues?
  2. Jul 27, 2012 at 3:06 PM
    mh.meier
    mh.meier Not PB Mike
    The Doctor
    Commiefornia
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper (12+ conversion) -Baja Designs Squadrons -Baja Designs S8 20” -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -Pelfreybilt Sliders -BAMF Bed corner tie down brackets -Custom chopped front fenders -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Sway-A-Way 2.0 rear ext travel shocks -OME Dakar HD pack with extra AAL -35" Falken MT01s -16" SCS SR8's in Black -Kustom 54 Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I have spacers with my 285/75/16's and had no issues with my old 265's. You should be fine. I didnt rub until I upgraded tires.
  3. Jul 27, 2012 at 3:09 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    thanks mh. meier
  4. Jul 27, 2012 at 3:09 PM
    mh.meier
    The Doctor
    Commiefornia
    No prob. If you dont mind, which spacers and how wide were you going with?
  5. Jul 27, 2012 at 3:13 PM
    medic2230
    Murph
    Bama! Roll Tide
    The only difference you will see between those two tires will be in height not width.
  6. Jul 28, 2012 at 11:16 AM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Not sure what width. I guess maybe the 1.25". Just hope that gives me the stance I want. Not sure if I need to go with the 1.50"
  7. Jul 28, 2012 at 11:29 AM
    mh.meier
    The Doctor
    Commiefornia
    I have the SpiderTraxx 1.25's and they make aa very notable difference.
  8. Jul 28, 2012 at 4:45 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    Well looks like I'll go with the 1.25", thats the only choice you get from toytec per the order screen.
  9. Jul 28, 2012 at 4:50 PM
    Fox2011PM
    '13 DCSB 4X4 TRD OR
    According to toytec's spidertraxx order screen, the 1.25" are for '01- current tacomas, and the 1.50" are for '95.5-'00 tacomas. Correct me if I'm wrong. I'm also just hoping the 1.25"s move my tires out enough to give the stance I want.
  10. Jul 28, 2012 at 4:54 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Either spacer will cause 265/75-16 tires to rub the mudflaps near full lock.
  11. Jul 28, 2012 at 4:56 PM
    mh.meier
    The Doctor
    Commiefornia
    They gave me a wider more aggressive stance. you could go further out with other spacers but ST are well known and make a good product that wont shit on you.
  12. Jul 28, 2012 at 4:57 PM
    mh.meier
    The Doctor
    Commiefornia
    KenLyns is right, at full lock you might rub but I just took my mudflaps off and trimmed the entire inner wheel well.
