Wheel spacer
Discussion in '5 Lug' started by 808tacomas, Nov 1, 2012.
  1. Nov 1, 2012 at 8:17 PM
    808tacomas
    808tacomas [OP] Well-Known Member
    kingrob
    oahu
    2011 toyota tacoma 4door 4 cyl.
    working on it..need some advice
    I'm going to grab me 235/75 and some wheel spacers. What size wheel spacers do I get so that it doesn't rub. Or will it even rub? Or if I get wheel spacers can I put on bigger tires with out rubbing? Thank TW
  2. Nov 2, 2012 at 8:39 PM
    paid4c4
    paid4c4 Well-Known Member
    Northern KY
    2015 4X4 TDR Sport, Auto Extended Cab
    You didn't state which size you are getting 15, 16, 17 or 18 inch. I am currently running 235/75/15 on my 2010 4 cylinder, 5 lugger and it doesn't rub at all. The tires make all the difference in the world in the truck, I'm glad I went with the 75's.
    Bill
  3. Nov 6, 2012 at 7:43 PM
    808tacomas
    kingrob
    oahu
    I'm rockin da 15 too. I heard it doesn't rub but I want it to stick out more. So I was wondering if I go 235 75 15 and put like a 1 inch wheel spacer will it rub or it'll be good?
  4. Jan 16, 2013 at 3:57 PM
    MIAtaco
    MIAtaco Well-Known Member
    Brian
    Miami FL
    2010 tacoma base lifted
    2.75" front lift 2.5" rear, pro comp es3000 rear shocks w/ orange shock boots, custom exhaust, k&n cold air intake, 20" led light bar behind grill, aftermarket grill, T-rex3 eyelids, pioneer HD radio
    what rims are you gonna use? im running 235/75/15's with some MB wheels and before i lifted it they rubbed a little and be careful spacing them so they dont crush your fender on hard bumps
