Wheel spacers, yes or no?
Discussion in 'Wheels & Tires' started by consultadrone, Dec 11, 2016.
  1. Dec 12, 2016 at 4:03 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    1" Bora spacers on my truck with 108,000+ miles. Never a problem. No different that wheels with more offset. I do NOT use lock-tite. Never had a loose lug yet. And I do off road the truck quite a bit.
  2. Dec 12, 2016 at 4:09 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Been running em for a while now with zero issues
  3. Dec 12, 2016 at 4:15 AM
    jztacoma
    jztacoma Trust me I’m an Engineer
    Upstate NY
    2024 Tacoma TRD Offroad
    Semi Stockish
    Been running my 1" Bora Wheel Spacers for 4,000ish miles now (maybe little less). So far 0 issues.
    When you install them you just need to make sure to really follow the directions. Torque correctly. Do not use an impact gun. Do a 5-10 mile test drive, take the wheels off and re-check all the torques. Every time you rotate the tires just re-check the torque. Mine haven't budged one bit.
    A higher quality is typically a wheel spacer that has had some thought put into it and some engineering. A Bora wheel spacer is hub centric for both the wheel and the hub. Meaning all of the weight is supported by the hub and not the wheel studs. Exactly the same as if you bolted your OEM wheel up without the spacer.
    The wheel spacer just acts like as if you had a less offset wheel, so stresses on wheel bearings are the same regardless.
    You run into issues when its a more universal spacer, or you dont follow proper install or maintenance on them.
    $200 for a good spacer is still less then $500+ for new wheels. And like you said you want that close to OEM look. Another tidbit is that an OEM wheel is significantly stronger then most aftermarket ones.
  4. Dec 12, 2016 at 4:17 AM
    jztacoma
    Upstate NY
    Semi Stockish
    Picture dump for a 1 inch spacer
  5. Dec 12, 2016 at 4:28 AM
    dragonhrt
    dragonhrt Well-Known Member
    Ottawa
    07 TRD Offroad
    OME 3 Inch Lift, 5100's
    I have a full set (4) spidertac 1.25" (blue) sitting in the my basement collecting dust. 2 have never been used. I needed them when I had the pizza wheels with a 3 inch lift. That truck (2007) is sold now and I have no plans to put a lift on this one (2013).
    GMAN62465, Jeremy4x4 and DustStorm4x4 like this.
  6. Dec 12, 2016 at 4:35 AM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    I personally want my wheels tucked under my truck, mainly because I don't like rocks hitting and scratching the sides of my vehicle.
  7. Dec 12, 2016 at 6:55 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Your truck can't tell the difference between wheel spacers and aftermarket rims. Both will have the same affect on wheelbearings.
    I have also been running wheel spacers with no negative effects just check them when you rotate tires and I personally use Loctite
  8. Dec 12, 2016 at 7:45 AM
    Shaun23a11en
    Shaun23a11en Well-Known Member
    Shaun
    So. Cal
    2009 TRD SPORT
    i have spidertrax 1.25" all around and no problems. Just red loctite and torque. My lugs have not budged at all
    Jeremy4x4 and consultadrone[OP] like this.
  9. Dec 12, 2016 at 7:54 AM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Those 3rd gen TRD OR wheels are +25 offset.
    ChadsPride likes this.
  10. Dec 12, 2016 at 8:01 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    If you don't want to spend money on new wheels and do it properly. I'd say no more than 1" and I'd go with bora imo.
    xsf18cdf and Jeremy4x4 like this.
  11. Dec 12, 2016 at 8:04 AM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    I bought my 1" spacers in a group buy here on TW three years ago. I installed them and a few days later retorted them and they stayed at the same torque ever since. I can't remember what brand they are, but I know they're not Bora or Spidertrax.
    Jeremy4x4 likes this.
  12. Dec 13, 2016 at 2:45 PM
    Squirrelbomb
    Squirrelbomb Well-Known Member
    Lost in Montana
    16 DCLB OR
    I got called stupid for bringing up the same issue on this site...
  13. Dec 13, 2016 at 2:53 PM
    consultadrone
    consultadrone [OP] Well-Known Member
    Orange County, CA
    '15 DCLB
    I hear ya. I've been called stupid for far less.
    johnnybuck2 and TacoDoe858 like this.
  14. Dec 13, 2016 at 2:53 PM
    DEMikey
    DEMikey Mr. Badwrench
    mikey
    delaware
    2013 red taco
    100XR, OTW Surf Rod Rack, Toytec 3" lift, +1 on tires
  15. Dec 13, 2016 at 2:56 PM
    #35
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    You won't notice any extra wear off a 1.25" spacer.
    End of thread.
  16. Dec 13, 2016 at 3:01 PM
    #36
    DEMikey
    mikey
    delaware
    2013 red taco
    i should add, that the only off roading i do, is in the sand. im not a trail guy, or mud. i surf fish a lot and drive on the beach.
  17. Dec 13, 2016 at 3:11 PM
    #37
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    I have been running avid off road wheel spacers since I bought my truck new, 4 years and 40k miles no issues, and I do a lot of hard offroading
  18. Mar 31, 2018 at 7:46 PM
    #38
    ARtaco12
    ARtaco12 Member
    Arkansas
    2012 TRD OR
    Husky front mud flap
    Going to put this here instead of starting a new thread.
    Ok guys, need some advice and thoughts...
    I have a 100k+ mile 2012 4x4 Tacoma DC, TRD OR, NON-TSB 3 leaf, totally stock (well, front husky mud flaps). Currently with 1.5" rake. Here what I'm thinking about doing:
    1) Bilstein 5100 at 0.85 in front
    2) Toytec 1/2" shims in rear with 5100
    3) 1" wheel spacers
    4) 265/75/16 duratracs or similar
    My question: Will I rub?? I do quite a bit of off roading so I don't want to rub in those situations either. Will the spacers worsen or improve the chances of rubbing? Overall, anybody see other flaws in what I'm attempting? Thanks!!
  19. Mar 31, 2018 at 7:54 PM
    #39
    D Soulman
    D Soulman Well-Known Member
    Dan
    Fargo, North Dakota
    I have run them on several vehicles (two LCs, 1 T4R) with zero issues. I use Spidertrax and have the 1.25" on my current 4R. The stance looks perfect IMO. Just check at rotation time as stated above.
  20. Mar 31, 2018 at 8:06 PM
    #40
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    Just installed 1.25" spidertrax last week. Happy so far. Gives truck a nice stance.
