Wheel spacers, yes or no?
Discussion in 'Wheels & Tires' started by consultadrone, Dec 11, 2016.
  1. Apr 19, 2019 at 11:46 AM
    #121
    Jaybird947
    Jaybird947 Active Member
    Jay
    19 Tacoma SR Double Cab 4x4 Super White
    I actually bought them off of Amazon. They’re Dynofit brand. They seem really solid and installation was a breeze. The threads off of the hub sit perfectly inside the spacer with no issues.
  2. Apr 19, 2019 at 11:51 AM
    #122
    wmitch352
    wmitch352 Active Member
    Colson
    2017 tacoma trd sport
    6" pro comp
    hub centric? no vibrations?
    fökai671 likes this.
  3. Apr 19, 2019 at 12:34 PM
    #123
    Jaybird947
    Jay
    I do have some hubcentric rings on the way. These are 108mm but there are no vibrations at all. Feels like a factory ride. Maybe better with these tires actually lol
  4. Apr 23, 2019 at 11:17 PM
    #124
    Talkingmute
    Talkingmute Active Member
    Alaska
    '10 Taco SR5 4wd 5spd Acc. Cab 2.7L
    3" OME, AFE CAI, URD Header, ARB +Warn M8k
    Just popped some spidertrax 1.25's on because the new 285/75's were grabby on the UCA.
    I see people talking about putting a set on the back? Why? What function do they serve on the rear?
  5. Apr 24, 2019 at 1:56 AM
    #125
    Jaybird947
    Jay
    I don’t think it’s the function most folks are going for on the back. The look of a good offset and the wider stance. Which also gives slight handling and stability increases also. In my opinion ay least.
  6. Apr 24, 2019 at 8:55 AM
    #126
    DarthPow
    DarthPow Well-Known Member
    2012 DCLB TRD Sport 4x4
    Also to maintain the same track width front and rear. not sure how much difference it makes in practice, but that's a reason.
    Jaybird947 likes this.
  7. Aug 15, 2019 at 11:14 AM
    #127
    Coach L
    Coach L Member
    Nic
    2011 Black DB LB Tacoma
    Spryder spacers 1.25, cold air intake, bull guard, kc lights
    So I am not into posting, never done it before, but this sites has helped me a lot the past few years. I know this is an old posting, however, I just put some spidertrax 1.25 on and they look great. It's exactly what I was looking for. I wanted a more aggressive look and a little bit wider stance and they work perfect. I will stay I wasn't expecting rubbing but there was, a 24 dollar investment in a hot air gun and I molted and melted the plastic back in towards the frame. So far so good. You guys also ask for pictures a lot so I hope I don't disappoint.
    Side note I would love to get new wheels and tires along with a 3inch lift kit later down the road. My justification is that it's paid off, I not buying any new toys anytime soon and tacos usually last forever, so why the hell not spend a 3k on a look that makes my truck look mean and mine.
    Minny Taco and lechicklet like this.
  8. Oct 10, 2019 at 1:58 AM
    #128
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    Full OME 883s, SPC UCAs, 33" STT Pros
  9. Oct 10, 2019 at 8:28 AM
    #129
    DarthPow
  10. Oct 10, 2019 at 1:37 PM
    #130
    jeg0005
    Jon
    BHM, AL
    So 1” would be better?
  11. Oct 10, 2019 at 3:42 PM
    #131
    DarthPow
    Yea, I would think so, unless your rims have the recesses, then you could go with the .75", and the wheels wont stick out as much... but if that doesn't matter to you, or if you want that for the looks, then yea, go with the 1".
  12. Oct 10, 2019 at 3:51 PM
    #132
    Acabsurf
    Acabsurf Well-Known Member
    Alex
    San antonio, Tx
    2015 silver SR5 4x4
    Fabfour vengeance front bumper, XD series wheels. Leveling kit.
  13. Aug 21, 2020 at 4:17 PM
    #133
    1tacoplease2.0
    1tacoplease2.0 Well-Known Member
    RJ
    Hawaii
    2008 S4x4 Access Cab SR5 6 speed manual supercharged
    I’ve been running 1.25” spidertraxx for over 100k and am off road maybe 5% of all that. I’ve had to replace my passenger wheel bearing and I have to replace my lower control arm ball joint and bushings soon. So the long term use does wear on the components faster. With all that said, I’m still running them and will continue to.
  14. Aug 22, 2020 at 9:59 PM
    #134
    EricOutside
    EricOutside Well-Known Member
    Eric
    NW Washington
    2014 DCLB Sport 4x4
    Home-built roof rack for spotting platform and/or kayaks & bikes & stuff. Home built bed drawers Firestone Ride-Rite airbags on the rear for level camp trailer towing
    So... this may not be the thread to ask, but here goes. I noticed the bolt pattern for the wheels on our Jayco Hummingbird camp trailer is the same as our 2014 Tacoma. It occurred to me it'd be nice to have interchangeable spares. I pulled one of the trailer wheels and it bolted right up to the Tacoma, though I haven't driven on it. I measured the dish of both rims and it looks like I'll need a 1.5" spacer on the trailer to for the deeper Tacoma wheel to line up.
    Is this nuts? Are there other considerations that I'm not aware of that would make this a bad idea?
    1tacoplease2.0 likes this.
  15. Aug 25, 2020 at 10:22 AM
    #135
    EricOutside
    Eric
    NW Washington
    2014 DCLB Sport 4x4
    I've been researching this more and found an interesting response at eTrailer here:
    "... I do want to make you aware that the sidewall of a vehicle tire are not built as strong as the sidewall of a trailer tire, so overheating and blowouts could be more common..."
    https://www.etrailer.com/question-193574.html
    You know, for those of you following along...
  16. Sep 23, 2020 at 11:45 AM
    #136
    Adrianc0143
    Adrianc0143 Member
    Adrian
    LAS CRUCES NM
    2017 TRD TACOMA DCLB
    BILSTEIN 6112 AND 5160 LIFT WITH 650 LBS COILS, east coast gear supplies bushing, backflip mx4. BODY ARMOR HIGHLINE FRONT BUMPER WITH SMITTY BUILT 10K LBS COMP WINCH.
    My 2 cents is that I tried 1.25 " and hated the fact that I couldn't keep my mud flaps and stock look due to rubbing. I have 265 75 16 tires and just didn't work with my Bilstein 6122 5160 set up. Sad because I liked the look but took them off within 48 hours. Wheels spacers on the 3rd gen dclb just don't fit with the small wheel well. Hope my experience helps you all out.
  17. Sep 29, 2020 at 7:42 PM
    #137
    Arcteryx 79
    Arcteryx 79 Well-Known Member
    RJ
    Waukesha WI
    2020 Black TRD Sport DCLB
    You rubbed with that set up? You are the first person that has said that about that tire size and offset/spacer set up. Also with those shocks are you running at stock height?
    Not arguing. Legitimately asking as I am keeping stock height with same tire size. Just want a little more aggressive stance.
  18. Oct 24, 2020 at 1:52 PM
    #138
    Adrianc0143
    Adrianc0143 Member
    Adrian
    LAS CRUCES NM
    Highest setting on the 6112's. Still rubbed like crazy!!! Don't do it! You will be totally bummed.
  19. Nov 27, 2020 at 12:55 PM
    #139
    brianvanriot
    brianvanriot Member
    Brian
    2019 Quicksand Tacoma SR5
    you wanna sell those spacers amigo?
  20. May 21, 2021 at 7:52 AM
    #140
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I just installed Spidertrax 1.25 spacer on my method wheels 16x8 0-offset with 285/75/16 BFG Ko2’s. The stance looks awesome however now I’m rubbing all over the place....ugh!!!!
    Has anyone maxed out there camber adjustments (pushed forward) to help reduce the rubbing?
