Wheel spacers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TiComa_316, Feb 10, 2016.
  1. Feb 10, 2016 at 8:55 PM
    TiComa_316
    TiComa_316 [OP] Active Member
    Ti
    Wichita, KS
    2015 Toyota Tacoma TRD OffRoad
    3" Rough Country lift Rough Country nerf rail DDM 3000k hid fog lights DDM 5000k hid head lights 15% tint all around 6" AntennaX Black front grill (Camelback) AVS Window visor FN BFD 18x9 wheels Xtralights Black Housing headlights Access Vanish Roll-up Cover
    What do you guys think about wheel spacers? Are they okay to use or are they bad overall? How big would you go until it be consider ridiculous?
  2. Feb 12, 2016 at 6:58 PM
    Jrozz
    Jrozz Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    dont
    go bigger than 1.25. and loctite the threads and torque them to spec. i have them on mine. the only issue is that it obviously makes the wheel stick out farther so it can rub on stuff especially your cab mounts
  3. Feb 12, 2016 at 8:00 PM
    tacoparadise
    tacoparadise Well-Known Member
    2012 tacoma 4x4
    they add unwanted stress to the hub bearings.
    poorly made wheel spacers can fail. (i have seen this before)
    it would be better to buy properly spaced offset wheels.(jmho)
    TiComa_316[OP] likes this.
  4. Feb 12, 2016 at 8:04 PM
    apocataco2015
    apocataco2015 Well-Known Member
    Clayton
    Salado, TX
    2017 Tacoma TRD OR 4x4
    Fox/OME/Icon lift. TRD Beadlocks. Toyo MT’s. Pelfreybilt, RCI, Mobtown armor.
    I agree. I actually bought them for mine and have had them on for about 3 weeks. I'm getting them removed at my next tire rotation and then selling them. I don't like them as much as I thought I would. Plus they make my tires rub. Not worth it.
    tacoparadise[QUOTED] likes this.
  5. Feb 12, 2016 at 8:14 PM
    tacoparadise
    2012 tacoma 4x4
    i work for a major tire company and see too many bearings wiped out by oversized wheels with spacers. the wheels are hard enough on the bearings but add the extra spacing outward and the stress leverage added is a big deal.
  6. Feb 12, 2016 at 8:16 PM
    apocataco2015
    Clayton
    Salado, TX
    Yea I don't doubt that. Makes sense.
  7. Feb 13, 2016 at 2:52 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    If you get larger tires, you may need spacers (really wheel adapters) if the tire rubs on the knuckle. And if staying with OEM wheels, you may also need longer wheel studs. I've had spacers since about 30K miles; now up to 140K. I'm on my second set of wheel bearings but not because of the spacers.
  8. Feb 13, 2016 at 10:11 AM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    ive had my spidertrax on for over a year with no issues to wheel bearings. not saying it doesnt add stress, and yes a properly spaced offset rim would be a better choice. it was a cheaper option for me thats why i did it.
  9. Feb 13, 2016 at 12:14 PM
    Chuy
    Lakeside, CA
    Silver Taco
