Wheel Spacers
Discussion in 'Wheels & Tires' started by bamaboy0323, Jan 7, 2010.
  1. Jan 7, 2010 at 4:35 PM
    bamaboy0323
    bamaboy0323 [OP] Member
    Exactly how bad would it be to run wheel spacers so that you wouldn't have to do any trimming if you go with the 285/75/16's on the OME 3" lift?
  2. Jan 7, 2010 at 4:41 PM
    Bean
    Bean Well-Known Member
    Randy
    KC,MO
    2010 4X4 TRD Sport
    Step Bars, Wheels & Tires
    There are many people that use them without any problems. However, there are just as many that will tell you not to use them. They do put more stress on wheel studs, hub bearings, and other parts. It's your ride... Do what you want, just remember that if you save money not buying a lift or wheels that fit correctly, you may have to spend money on other issues. Depends on what you use your truck for. If it is your daily driver, think reliability. If it is a toy, you are probably already prepared to break stuff.
  3. Jan 7, 2010 at 4:41 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    not too bad at all if you go with spidertrax--there the best
  4. Jan 7, 2010 at 4:52 PM
    bamaboy0323
    Got cha. thanks guys.
