Wheel/Tire/Bearing noise? 2nd Gen
Discussion in 'Technical Chat' started by dreed47, Aug 7, 2024.
  1. Aug 7, 2024 at 10:29 AM
    dreed47
    dreed47 [OP] Well-Known Member
    I have a 2009 access cab with relatively new tires (less than 6k). I'm getting a road noise that I'm not sure what it is and figured I would ask here to see what people think. The noise seems like its coming from the left front side, it speeds up and and slows down relative to how fast I'm going, it's unchanged when I slip it into neutral (I have a manual trans). The noise almost goes away when I make a right turn but doesn't change at all when I make a left turn. Inspection of the tire I dont notice anything obvious like uneven wear or anything stuck in the tread or side wall of the tire. The front disc brake pads, rotars and dics were changed by my local Toyota dealer several months ago.
    Any thoughts on what this might be?
  2. Aug 7, 2024 at 10:34 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    How many miles on the truck itself?
    If you have a reason to suspect tires its easy enough to do a temporary rotation.
    That said a very common sign of a bad front bearing on these trucks is noise while corning one way and not the other. They very rarely fail the 'push-pull' test from what I read
  3. Aug 7, 2024 at 10:45 AM
    dreed47
    86k miles. If its bad wheel bearing how can I test it if fails the 'push-pull' test?
  4. Aug 7, 2024 at 11:04 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Sounds like a bad front right wheel bearing to me.
  5. Aug 7, 2024 at 11:05 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    It is likely your left front bearing. One way to determine what side bearing it is while driving down the road is to turn slightly to the right or sway to the right. If the noise lessens or goes away it’s your left bearing. If you sway or turn to the left and the noise diminishes it’s your right bearing.
    Expected life of front bearings is 100000 miles. May last longer or may wear out before 100000 miles.
  6. Aug 7, 2024 at 11:09 AM
    dreed47
    thanks, any merit in replacing both left and right or not really necessary until the right actaully goes bad? Also, should I buy the bearing and hub assembly or is it easy enough to just replace the bearing?
  7. Aug 7, 2024 at 11:16 AM
    TnShooter
    Deogee
    STOCK
    I’d do them both. They typically fail with 15k miles of each other in my experience.
    Look for bearings with SKF or NSK bearing. Don’t buy them from eBay or Amazon.
    Too many fake bearings out there.
    You could buy them from Amazon, but make sure it comes from a reputable seller.
    Sprig likes this.
  8. Aug 7, 2024 at 11:22 AM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-oe-nsk.537080/
    Dealer will charge you an arm and a leg for 1 this member will send you both for a good price. You can install or have a trusted mechanic do it for you.
    This is what I will do when I need a new one and I will get both done at the same time. Just because as the saying goes if 1 light goes the other one is not far behind. That's my opinion. The question no one has asked have you put a lift in recently?
  9. Aug 7, 2024 at 11:34 AM
    Sprig
    Ken
    I agree with TnShooter, replace both. One failed a little early, it’s likely the other wont last a whole lot longer.
    Tiedie and TnShooter like this.
