Wheel tire size help
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jabeztaco, Oct 17, 2020.
  1. Oct 17, 2020 at 7:24 PM
    Jabeztaco
    Jabeztaco [OP] New Member
    Hey
    So after 3 Tundras I just bought my 1st Tacoma and of course looking at wheels and tires. I know this subject has been discussed many times but would appreciate the help. It’s a 2020 SR5 dbl cab long bed. A guy modifiedtaco posted pics that were awesome he’s running 35’s on black rhino overlands not sure on his lift & mods. I use it for work and often drive 600 miles in a day so want to keep a lift at 3” max with no rub, grinding or cutting. Suggestions on a good lift and biggest tires would be appreciated. Also thoughts on the black rhino overlands? Thanks!
  2. Oct 17, 2020 at 7:36 PM
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
  3. Oct 17, 2020 at 7:38 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Hey
    Welcome aboard
  4. Oct 17, 2020 at 7:45 PM
    Mason27
    Mason27 Well-Known Member
    Mason
    Houston, Texas
    2020 Cement TRD OR
    Welcome to Tacomaworld
    With a frequent 600 mile daily drive, in all honestly I wouldn't suggest any kind of lift or even bigger tires. That being said, you should be able to fit 265/75/16's without any kind of lift, cutting, or rubbing. If you step up to 285's (33's), you will most likely have to do a cab mount chop regardless of lift height (cutting, grinding, welding). From what I've read on here, there is quite a bit of work that goes into fitting 35's. Spend some time on the suspension & tire threads, as well as this one: https://www.tacomaworld.com/threads...ould-you-still-have-lifted-your-truck.686496/
    Congrats on the truck, they're awesome!
    71tattooguy likes this.
  5. Oct 17, 2020 at 7:50 PM
    Jabeztaco
    Thanks I really like the truck and the stock ride is awesome I would just like a little for height and a bit
    Beefier look. Stock is 245/75/16. Thanks
  6. Oct 17, 2020 at 8:12 PM
    The_Devil
    The_Devil Well-Known Member
    E
    2018 Tacoma TRD Off-Road
    DIY Tonneau, Toolbox, Lift, TRD Wheels, TRD Grill
    Lifted, getting 15MPG highway. Also have 200lb bumper winch setup and 33" tires.
    My advice is Bilstein 5100 front and rear, OEM springs, no need for UCA.
    Icon 51100 AAL in rear. (It's a bolt on).
    You will end up 1.5" rear, 2" front lift.
    You will get and additional inch if you go to 33" tires.
    No cutting required if you go with wheels with proper offset. On TRD OR, not sure about your setup.
  7. Oct 17, 2020 at 9:56 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I’m lifted 2” front with 5100’s and aal. I did decide to get spc’s to dial in alignment. What a difference. Just my 2 cents.
  8. Oct 18, 2020 at 7:47 AM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    What kind of improvement do u notice with the new uca's?
  9. Oct 18, 2020 at 8:22 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Great alignment numbers tracking on freeway. Truck was wondering a little. Feels much more controlled and overall driving. Corrected some positive camber also. Super stoked.
    Shades_Of_Red[QUOTED] likes this.
