Wheel Weight benefits?
Discussion in 'Wheels & Tires' started by jmandeville, Apr 5, 2013.
  1. Apr 5, 2013 at 8:13 AM
    jmandeville
    jmandeville [OP] Member
    Justin
    Alabama
    None yet
    I know this is probably one of those topics that will start some arguments, but I was wondering if anyone had some numbers for benefits of lighter wheels. When I had my last truck I had some heavy motto metals with heavy tires totaling about 100 lbs per wheel. With my new truck I’m trying to keep it light so that I might get better fuel mileage and acceleration. So what are the opinions of those of you that have SCS F5's or Konig countersteer's? Are they worth it or should I just get some that I think look good?
  2. Apr 5, 2013 at 6:40 PM
    TahoeChris
    TahoeChris Well-Known Member
    South Lake Tahoe Ca
    2012 tacoma 2.7l 4x4
    OME 885 no top plate spacer OME nitro charger front and back Deaver 1.5" aal Sway bar delete
    I had the same concerns as you about tire/wheel weight. With stock 16" steel rims and the grandtreks in a 245/75 16 the tire/wheel weight is 64 pounds. After a lot of research I ended up going with the scs f5 and duratracs in a 265/75 16. That tire/wheel weight is also 64 pounds. I do notice a slight power loss going over mountain passes 8000+ feet, I haven't notice a loss in mpgs. I personally like the scs wheels. The fact that they are light weight was what sealed the deal for me. Also they are hubcentric not lugcentric like most aftermarket rims so no hub rings and they balance out really easy.
  3. Apr 7, 2013 at 11:26 AM
    DevL
    DevL Well-Known Member
    So you have to use non acorn style lugs? Did you reuse the factory lugs?
  4. Apr 7, 2013 at 11:36 AM
    DevL
    I see that SCS uses hub centric as a marketing tool for the uninformed. They are lug centric with a properly sized hub hole. There is no actual advantage to any company that does the same but calls the lug centric. They all center with the acorn style lug and the hub hole could be oversized or not with no difference. Hub rings are only for use with hubcentric wheels with flat lugs and wrong sized hub hole. A non issue for 99.99% of wheel purchases.
  5. Apr 7, 2013 at 11:40 AM
    BuzzardsGottaEat
    BuzzardsGottaEat "Pick up some speed.. You'll make it."
    Chaz
    South Dakota
    93 Pickup 4x4 [22R-E] 5MT
    OME suspension, LCE Performance parts, Konigs, etc. [see build]
    I went up nearly 4" in tires diameter but dropped significantly in weight in the process and broke about even from mpg, etc.
    My konig plus ATM combo puts me at about 58lbs per tire. It helps me a lot more than someone with a V6 since I'm pushing something like 120+ hp.
  6. Apr 7, 2013 at 12:52 PM
    jmandeville
    Justin
    Alabama
    None yet
    So whether the wheel is hub centric or lug doesn't make a difference if you have the right lugs? This is my first non Chevy and on all of them I did not have to take this into consideration when buying wheels?
  7. Apr 7, 2013 at 1:04 PM
    ABregenzer
    ABregenzer Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    :confused:
    Where are you getting your info sir?
    There is a distinct difference in hub-centric and lug-centric wheels.
    Hub-centric wheels will fit only on a certain vehicle with a certain hub size and lug pattern where as lug-centric wheels are centered on the lug pattern, not on the hub size.
    As for the OP's question, I had stock steelies and now have SCS F5's. The weight difference will make add a slight increase in mpgs and what not. :eek:
  8. Apr 9, 2013 at 11:50 AM
    mynameistory
    mynameistory Well-Known Member
    Tory
    Redondo Beach, CA
    '12 MGM 4x4 DCSB TRD-OR 6spd
    Hey Chaz, are those the matte bronze Konigs? I'm diggin' em.
  9. Apr 9, 2013 at 11:52 AM
    BuzzardsGottaEat
    Chaz
    South Dakota
    Yes, sir. Matte Bronze.
  10. Apr 12, 2013 at 1:42 PM
    snipes285
    snipes285 Member
    2013 TRD Quad cab
    Hood deflector, window vents, Tonneau cover, NFab nerf bars
    I dropped 5.4 lbs per wheel combo going to the Stealth 6 wheels. Definite improvement in acceleration and I saw my best mileage to date at 23mpg, (typically 20-21mpg)...
