Wheel Well Liner "Grommets"
Discussion in '1st Gen. Tacomas (1995-2004)' started by CliffordBRD, May 5, 2013.
  1. May 5, 2013 at 9:22 AM
    CliffordBRD
    CliffordBRD [OP] Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    Curious to know if anyone has ordered these or replaced them with a part similar bought from advance auto, napa, etc...
    I found two parts online that are similar, but I'm not sure which one to get or if I can just go grab a substitute from the parts store.
    These are the two sizes I've found:
    1. Part # 90189-06028
    2. (I think this would be the right one for a 1998, but not sure)
    Part # 90189-06214
    Can someone help me out with this, I'd rather just go to the local store if they have a replacement...
  2. May 5, 2013 at 10:04 AM
    Madjik_Man
    Colorado Front Range
    It's interesting you just posted this. I'm not exactly sure what you mean by "wheel well liner" but if you're talking about the hard/rigid piece of plastic that lines the inner/upper part of the fender, then yes those should work.
    I just noticed that a few of the grommets that hold that flexible skirt (that prevents water/crud from getting into the engine bay?) are missing from my truck. I'm in search of those grommets, which are different that the ones you posted.
  3. May 5, 2013 at 10:13 AM
    CliffordBRD
    Cliff
    Tampa, FL
    They are square (rectangular?) holes that hold that liner in place. I just replaced my antenna and broke pretty much every single one of them.
    I'm just not sure which size I'm going for or if there is an alternative that I won't have to pay for shipping on..
  4. May 5, 2013 at 11:34 AM
    Sankuh
    Sankuh Active Member
    Nevada
    02 Ext. Cab 2.7 5 Speed
    I just pulled one out and brought it into autozone and found the ones that match it.
    Easy enough for me, they were only $3 for a 4 pack.
  5. May 5, 2013 at 3:51 PM
    Inverno4
    Inverno4 Well-Known Member
    Baltimore, MD
    2020 DC Off-Road MT
    You can get comparable ones for cheap at Lowes or Home Depot if you root around.
  6. May 6, 2013 at 5:16 PM
    kurts74
    kurts74 Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    I found some at Ace and Autozone.
