Wheelers Off-Road Bumpstops: Who's got them?
Discussion in 'Suspension' started by 08pretaco, Apr 25, 2011.
  1. Aug 21, 2016 at 3:42 PM
    #81
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Ha!!!put them back on the flip plate loosened them from there!!!:D
  2. Aug 21, 2016 at 3:48 PM
    #82
    DrFunker
    DrFunker Well-Known Member
    o_O are you having a conversation with yourself @303tacoma ? :D
    303tacoma and IronPeak like this.
  3. Aug 21, 2016 at 4:02 PM
    #83
    303tacoma
    Rebecca
    Yes :)
    And it wouldn't be the first time!!
    Crom and DrFunker[QUOTED] like this.
  4. Aug 21, 2016 at 4:06 PM
    #84
    DrFunker
    @303tacoma I just put those on my truck last week and I didn't even look to see how they were attached to the post.
    Really should have checked that. :anonymous: Was tired, was getting late.
  5. Aug 21, 2016 at 4:12 PM
    #85
    303tacoma
    Rebecca
    Ya I tried and tried to loosen them off the truck, then the light bulb went on!!! Put them back on the truck... Loosened right up... You will need longer bolts with the spacers
    Figured I share in case anyone else runs into the same issue
    :D
    DrFunker[QUOTED] likes this.
  6. Aug 21, 2016 at 4:14 PM
    #86
    DrFunker
    :thumbsup:
    Good to know. Thanks for doing the heavy lifting.
    303tacoma[QUOTED] likes this.
  7. Aug 21, 2016 at 4:14 PM
    #87
    303tacoma
    Rebecca
    Sure anytime!!!
  8. Aug 25, 2016 at 10:42 PM
    #88
    Svizzusi
    Svizzusi Lifted 2009 4x4 DCSB
    San Luis Obispo, CA
    Bilstein 5100/ OME 887/ 285/70/17 BFG KO2/ 17" ProComp 7032/ OME Dakar/ LR UCA/ Superbumps/ AllPro Flip Kit
    I bought two 1/4" spacers with my bump stops. Would it be more beneficial to put them on the front bumpstops or on the back bumpstops? I was thinking that I was getting 4 that's why I ordered them
  9. Aug 27, 2016 at 5:39 AM
    #89
    303tacoma
    Rebecca
    That's a pretty broad question you need to measure and figure out where you need them... Search and research!! Here is one thread and there are more..
    https://www.tacomaworld.com/threads/setting-up-bumpstop-suggestions.422472/
  10. Oct 6, 2016 at 2:44 AM
    #90
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Just installed SuperBumps in the front of my Tacoma(bone stock suspension). I took it for a 0200 test drive through a speed bump filled parking lot and the Superbumps made those speed bumps feel way smoother. Stock rubber was pretty jarring. Superbumps made those same speed bumps smoooooooth at both low and higher speed. Cornering seems a little firmer and nose dive on braking isn't as bad.
    For the record I was hitting my stock bump stops pretty regularly out on forest roads. Not a pleasant experience with the stockers. I have a feeling just based on my first test drive the Superbumps will be awesome.
    The only comment I have is they were a motherfucker to install. I ended up using a 1/4" drive deep socket and an 8mm bit to get them installed, but only after I spent the time to cut the supplied allen key only to find it was still too long. It would be nice if Wheeler's would at least include a usable tool for installs that are done without dropping the LCA.
    YotaDan likes this.
  11. Oct 6, 2016 at 4:47 AM
    #91
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    After doing a few installs, I just throw the key in a vise and chop about an inch off. Then throw the truck up on jack stands at full droop and install them. Never had an issue in the front doing it this way.
    YotaDan, Sna and 303tacoma like this.
  12. Oct 6, 2016 at 12:41 PM
    #92
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    I think the first issue was I only had a Dremel and files to cut it the key with and I broke my last cut off wheel. Took me a long time to cut 3/4" off and it wasn't enough to get the bolt started. I did have the truck at full droop.
  13. Jan 9, 2017 at 1:23 AM
    #93
    huli467
    huli467 Turning Octopus
    Honolulu
    2015 TRD Sport 4x4
    The world is big...and I want to have a good look at it...before it gets dark - John Muir
    What size socket did you use to remove the stock bump stops?
  14. Jan 9, 2017 at 5:18 AM
    #94
    303tacoma
    Rebecca
    I used some channel locks but my passenger side was so stuck I had to use a pipe wrench to get it out!!!!
    CharlieCafe likes this.
  15. Jan 12, 2017 at 6:24 PM
    #95
    CharlieCafe
    CharlieCafe Well-Known Member
    Charles
    Wherever the wind blows
    24 Tacoma TRD Offroad Premium 4x4
    Plethora of "useless" shit
    Pipe wrench here too!
  16. Jan 13, 2017 at 12:45 PM
    #96
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    So the Allen key that came with is 8mm? Any chance of using a hex-socket On ratchet?
  17. Jan 13, 2017 at 12:50 PM
    #97
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    just tape the socket on so it wont stick inside the bumpstop
    REDdawn6[QUOTED] likes this.
  18. Jan 13, 2017 at 8:41 PM
    #98
    randomguy
    The Dalles, OR
    17 T4R 4x4 MGM
    Possibly with the right extension just long enough to enter the bump stop.
  19. Jan 14, 2017 at 10:27 AM
    #99
    heffer
    heffer Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    I used a hex socket on mine.
    Lord Helmet likes this.
  20. May 24, 2017 at 2:06 PM
    #100
    Lostsheep
    Lostsheep Well-Known Member
    NorCal
    2015 6spd 4x4 OR
    6112s and 5160 , Dakars , Superbumps x4 , u-bolt flip , All Pro Skids (hacked and raised) , 265/70R17 KO2s, SEMA wheels, couple of machined things here and there
    I cut an Allen to be just long enough to protrude out of the superbump and then used a ratcheting wrench.
