Wheelers off road steel wheels
Discussion in 'Wheels & Tires' started by deadbolt, Oct 25, 2008.
  1. Oct 25, 2008 at 5:06 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    Hey guys,
    I was thinking about getting some wheelersoffroad steel wheels. They are the 16x8 black steel wheels. Im debating whether to go with the type A (4.5" backspacing) or type B (4" backspacing). If i went with the type B the wheels would come out more right? What do you guys suggest that i buy. I plan on putting BFG MT 265/75/16 on them. Thanks!
  2. Oct 25, 2008 at 5:09 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    with the 4 inch backspacing, yes...the wheel will sit out more. alos, remember that with the steelies, on the second gen tacomas,im pretty sure anyway, you may need to grind the calipers down a bit for a better fit.
  3. Oct 25, 2008 at 5:11 PM
    deadbolt
    Socal
    On the site it says it will clear the calipers.
  4. Oct 25, 2008 at 6:32 PM
    deadbolt
    Socal
    Anyone have these wheels?
  5. Oct 25, 2008 at 6:35 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you are good to go.....i was thinking about the first gen trucks and damn 15 inch steelies, which im getting soon.
  6. Oct 25, 2008 at 6:43 PM
    deadbolt
    Socal
    Thanks! Which would you go for? the 4.5 or 4 backspacing. Im thinking the 4 backspacing would give it more of an aggressive look since it sticks out more.hmm
  7. Oct 25, 2008 at 7:09 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    4 inch.
    Pretty good prices.
  8. Oct 25, 2008 at 7:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    4 inch as far as im concerned. its what im gonna get for my 04. plus, with those...less chance of tire rub on the uca's.
  9. Oct 25, 2008 at 7:35 PM
    deadbolt
    Socal
    i was reading on toyotanation that some guy had to do some trimming and had to take off the flaps when he put these wheels on 265/75/. I thought those tires would run fine wihtout trimming.
  10. Oct 26, 2008 at 8:42 PM
    deadbolt
    Socal
    Does anyone know if the TMPS works with these wheels?
  11. Oct 26, 2008 at 9:14 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im not real sure that the tpms will work with that steel wheel....my guess is probably not. there are ways to get around the whole tpms thing tho..........like putting them in a tube and keeping them set to a certain air pressure via a valve stem mounted on the tube. there is a write up somewhere for it.
  12. Oct 28, 2008 at 6:59 AM
    Jason07
    Jason07 Well-Known Member
    North Texas
    07 PreRunner
    I have the Wheelers type B on my 2007 Tacoma and I did not have to grind the calipers and the TPMS fits with no issues. The pics are older, I have recently taken the caps off because they started to fade really bad. Here are some pics.
  13. Oct 28, 2008 at 7:08 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Jason07 truck looks nice with those rims!
  14. Oct 28, 2008 at 7:26 AM
    Jason07
    North Texas
    07 PreRunner
    Hey, do u have your truck set at 2.5 in the front and 0 in the rear? I have been thinking of taking my 1 inch block out since my front has settled. When I look at my truck it looks like the rear is higher and I want the front to sit alittle higher.
  15. Oct 28, 2008 at 7:45 AM
    SocalMan22
    Steve-0
    So*Cal
    What Mods!
    Yeah 2.5" in the front and just the 5100's in the back sits nice.
