Wheels and suspension question
Discussion in '5 Lug' started by hachi-roku_fan, Aug 15, 2020.
  1. Aug 15, 2020 at 5:53 PM
    hachi-roku_fan
    hachi-roku_fan [OP] Member
    Hello everyone!
    I have a regular cab 5 lug 4 cylinder Tacoma (work truck special). Picked up bilstein 4600s from a third gen and I have a few questions;
    With no lift, the 4600s should work with no issues correct? From what I’ve read, it seems fine. I also have the UCAs from the third gen and do not know if they will swap over.
    For wheels, I’m looking at the procomp 51s from 4wheelparts. 15x8 -19 offset. I’ve heard that some 15s don’t clear the brakes so I want to make sure before pulling the trigger.
    Any help is appreciated! Thanks!
  2. Aug 15, 2020 at 6:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    This. The 6 lug / 5 lug interchange is 100% no bueno AFAIK.
  3. Aug 15, 2020 at 6:17 PM
    hachi-roku_fan
    Oh wow! Not even the 4600 shocks? I thought I read something here that said the shocks were ok. Hmm so for a daily, what would you guys suggest on that front?
  4. Aug 15, 2020 at 6:33 PM
    hachi-roku_fan
    Ok I got some homework to do then. Is there a rim guide somewhere for the 5 lug? Thanks for the info everyone!
  5. Aug 15, 2020 at 6:37 PM
    Clearwater Bill
    Billy
    Largo Florida
    https://www.amazon.com/BILSTEIN-SHOCKS-TOYOTA-TACOMA-ABSORBERS/dp/B01BOODZSE
    https://www.amazon.com/BILSTEIN-SHO...2EAB6RZ9714&psc=1&refRID=5J82JTDHB2EAB6RZ9714
    4600 is just a model number with various fitments. The 5 lug version is 36mm, the 6 lug is 46mm, and very likely other differences as well.
  6. Aug 15, 2020 at 6:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    You don't even tell us the year of your truck. Several wheels will work, including other Toyota wheels. Plenty of threads right here in this forum to review.
  7. Aug 15, 2020 at 6:54 PM
    hachi-roku_fan
    Whoops sorry guys, 2007.
    I did see the RAV4 wheels, but no luck finding any in my area at the moment.
  8. Aug 15, 2020 at 6:58 PM
    Clearwater Bill
    Billy
    Largo Florida
    I went for an old school look, using a set of spare tire wheels painted up and adding SS trim rings. The 235 75 15 tires add 1" of real ground clearance, no rubbing
  9. Aug 15, 2020 at 8:30 PM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    I've had two 2nd generation 5 lugs, one with RAV4 wheels and one with Highlander wheels.
    Both were straight swaps, just bolt on - just need the right type of lug nuts.
    hachi-roku_fan[OP] likes this.
  10. Aug 15, 2020 at 8:34 PM
    NewMexiMan
    NewMexiMan Well-Known Member
    2016 SR 5 Speed
    Wait, does 5 lug only refer to the 2wd versions of the Tacoma? Or any SR model? I have a 2016 SR 4x4 manual. Does that mean 6 lug parts won't fit my truck?
  11. Aug 15, 2020 at 8:40 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    5 lug means your wheels only have 5 lug nuts. Pretty sure they don’t make 4x4s in the 5 lugs.
    :facepalm:
  12. Aug 15, 2020 at 9:57 PM
    NewMexiMan
    2016 SR 5 Speed
    Yep, no 5 lug tires on mine. Came with the "black satins". Very classy.
  13. Aug 16, 2020 at 9:20 AM
    hachi-roku_fan
    What suspension setups are you running? Both trucks look good!
  14. Aug 16, 2020 at 10:34 AM
    TheBigKahuna
    Both trucks have unmodified stock suspensions.
    The silver one had 235 70 R16 tires.
    The pyrite mica has 225 70 R16 tires
  15. Aug 19, 2020 at 10:12 PM
    hachi-roku_fan
    So I’m now looking at mild lift options on the thread. I noticed that none mention the need for any special shocks and UCAs; is that correct with regards to the Procomp, FatBob, readylift kits? I am more than likely going to go with Bilstein 4600 shocks
    Already picked up blackened headlights, fog lights, pro grill, and a paint matched bumper. Hunting for RAV4 wheels at the moment.
  16. Aug 27, 2020 at 5:30 PM
    hachi-roku_fan
    So update for anyone that cares lol. Going for spacers up front and looking at third gen leafs in the rear. Is there any difference between 5 lug 2nd gens and 6 lug 2nd gens in the rear. 6 lugs seem to be ok with the 3rd gen rear with longer shocks. I just want to avoid having the same issue as I did with the shocks. Good news is I was able to sell the shocks so no money lost there. Thanks everyone!
  17. Sep 5, 2020 at 1:50 PM
    Tacomaken2015
    Tacomaken2015 Member
    New Jersey
    2015 2.7l access cab SR5 Package
    What year are the 235 70 R16 wheels ?
  18. Sep 5, 2020 at 3:01 PM
    TheBigKahuna
    Toyota RAV4 2001 - 2003
  19. Sep 7, 2020 at 5:49 AM
    Tacomaken2015
    New Jersey
    What about the highlander? Hub bore sizes differ on later years from 60.1.
  20. Sep 7, 2020 at 5:56 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pretty sure one mounts on axle top, the other on axle bottom.
    And from post 3
