Wheels Question Width and Offset
Discussion in '1st Gen. Tacomas (1995-2004)' started by 03toytaco, Jul 21, 2010.
  1. Jul 21, 2010 at 9:49 AM
    03toytaco
    03toytaco [OP] New Member
    03 TRD Tacoma 4x4
    CAI
    Hello,Everyone I'm a new member and just got my first 03 Toyota Tacoma 4x4 TRD xtra cab. Since Silver is a common color I thought maybe I'll do something different. There's 4 guys at my work that has the same truck as me. It didn't bothers me at first,til I got off work late and found myself trying to get in someone else truck. Anyway my questions is..my stock wheels size is 265/70/16. Will a set of black steel wheel 16x8.5 with a -6 offset fit on my truck without rubbing during turning? The wheels is made by MB Wheels 72. I'm not quite sure what the width and offset of the stock wheel are. I've contacted my local Toyota dealer and asked them about width and offset but they referred me Tirerack. And Tirerack refer me the Dealer. I'm tryin to go wit a Black wheel so that I don't look like everyone else but wanna be as close to the stock size 16 in. If anyone knows the companys/brands that make 16 inch black wheel Please let me know! Thanks in advance for any help/suggestions.
  2. Jul 21, 2010 at 9:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, they will fit fine without rubbing. That wheel should have about a 4" backspacing.
    You can check wheelersoffroad for cheap black wheels also.
  3. Jul 21, 2010 at 11:17 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you are still on the stock BFG Rugged Trails, Tire Rack says that a rim width between 7"-9" is OK for those tires.
