Wheels sticking out
Discussion in 'Wheels & Tires' started by DaytonLax14, Jan 26, 2010.
  1. Jan 26, 2010 at 7:42 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    What do I need or what do I need to do to make my tires/wheels stick out a bit? I don't want them to stick out a ton, but a few inches on each side. I am getting some 31s soon and think it would look meaner if they stuck out a little bit.
  2. Jan 26, 2010 at 7:43 PM
    oofy15354
    oofy15354 Proud Tundra *****
    Dave
    Massachusetts
    Herculiner, Access Tonneau, Uniden cb, firestik antennae, Bosch Wipers, JVC Ipod headunit, Boston Acoustic Speakers
  3. Jan 26, 2010 at 7:44 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    wheel spacers or different backspaced wheels
  4. Jan 26, 2010 at 7:46 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Hehe. You need a negative offset closer to 0. All you need is a -4 to -4.5
    Though, this is a regular ol' -4.5 and a beefy wide tire. Some tires are generally wider (Nitto, Toyo) than others (ie, BFGs)
  5. Jan 26, 2010 at 7:47 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    You guys and your wheel spacers! YUCK!
    I've seen too many "issues" with spacers on the track and so far. Our trucks wont push the limits of spacers like tracked cars but still.
  6. Jan 26, 2010 at 7:49 PM
    DaytonLax14
    Corey
    Ohio
  7. Jan 26, 2010 at 7:52 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    Those wouldnt get you the look you want because of the width of the wheel. Go with a 9" wide wheel.
  8. Jan 26, 2010 at 7:52 PM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    X2
    Here's mine with stock TRD Sport wheels and Spidertrax spacers and 33's...if my wheel bearings wear out I suppose I'll just replace them.
    IMO, the perfect amount of "stick-out-ness"!
  9. Jan 26, 2010 at 7:53 PM
    AriZonaD54
    Andrew
    Valley of the Sun
    do a google search for "wheel backspacing" and "wheel offset"
    it'll help you understand. google is your friend.
  10. Jan 26, 2010 at 7:56 PM
    DaytonLax14
    Corey
    Ohio
    gusher, I was thinking of more "stick out ness" than that. Like, 3 inches on each side
    edit- crager makes a wheel that is 15"x10". How would that make the tires sit? Would 31x10.5R15 fit them?
    Sorry for all the questions, i'm new to this stuff.
  11. Jan 26, 2010 at 8:00 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    spidertrax
    BAM!
  12. Jan 26, 2010 at 8:02 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Spindles stick the wheels out :D
  13. Jan 27, 2010 at 1:59 PM
    DaytonLax14
    Corey
    Ohio
    :eek:
  14. Jan 27, 2010 at 9:09 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    bad info... OP is a 1st gen taco... completely different stock backspace...
  15. Jan 27, 2010 at 9:23 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    your stock backspace is 4.5"
    if you are going to run 31s and want the tires to stick out, you want to go with a 15" wheel with 3.75" backspace which is pretty standard for most 1 st gen 15" wheels...
    if you want to stick out even further, a lot of the older 1st gen rock crawlers were running D-window steel wheels in 2.5" to 3.5" backspace...
    with 31s though, sticking out that much will look like you are running low profile tires...
    your best bet, look into either 15s in 3.75" backspace first and see if you like them out that far... if you want to go more extreme, then look into some 1" wheel spacers...
  16. Jan 27, 2010 at 9:27 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    4.75" backspace will sit way too close inside the wheel well...
    also, if you search "soft 8 wheels" in most of the tacoma forums, you will see a number of threads where folks have not been able to fit those wheels on 1st gen tacos for years without a wheel spacer, so you can drop the money on the wheels linked above and drop more money on 1" wheel spacers, or try to find another style of steel wheel in 3.75" backspace...
  17. Jan 28, 2010 at 6:56 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
  18. Jan 28, 2010 at 2:07 PM
    DaytonLax14
    Corey
    Ohio
    mike, thanks for all the info. Looks like I need to find me some new wheels...
  19. Jan 28, 2010 at 2:21 PM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    +2 for Mike....it's because of people like Mike that take time to explain to others is why TACOMA WORLD ...ROCKS :rockband: :thumbsup: and why I stick around!!:D
  20. Jan 28, 2010 at 2:58 PM
    DaytonLax14
    Corey
    Ohio
