Wheels that will fit now and work with lift later?
Discussion in 'Wheels & Tires' started by drivethruecp, Dec 5, 2010.
  1. Dec 5, 2010 at 11:53 AM
    drivethruecp
    drivethruecp [OP] Active Member
    I want to get "future proof" wheels for my 2008 TRD Sport before I get my lift if possible? I'm prerty set on my new wheels. Right now I'm running 265/70R17 tires on my stock 7.5" deep wheels. Haven't decided on a 3" or 6" lift yet just due to money and JUST bought the truck a month ago. So question is, what size wheels to get that would look right when lifted and offer me the larger tire choices (after lifting). I won't be doing any super serious off-roading, if that helps. Looking at possibly the Kumho Venture M/T KL71 as my first tires after.
    First thought was the 17x9, but with the 0mm offset and 9" width, will they fit my truck without spacers and the existing 265/70R17 tires before I add the bigger tires and lift?
    Mickey Thompson Sidebiter Wheel Specs:
    Part # Size Appx.Weight Bolt Circle Back Spacing Offset(mm) Load Capacity Replacement Cap
    158411 15x8.0 24 6x5.5 3.31 -30mm 2,000 401517
    150411 15x10 28 6x5.5 3.5 -53mm 2,500 401517
    168412 16x8.0 26 6x5.5 4.5 0mm 2,500 401517
    179412 17x9.0 30 6x5.5 5 0mm. 2,500 401517
  2. Dec 5, 2010 at 12:32 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    you are going to want 4.5" backspacing (backspacing is calculated using rim width and rim offset). With 4.5" backspacing, you can fit 265's now and switch to 285's once you lift.
    The only ones you posted above that have 4.5" backspacing are the 16x 8's.
    The 15's won't fit your truck at all due to brake caliper rubbing. some aftermarket 16's will also rub on the calipers so I'd check to see if anyone has these particular wheels in the 16x8, to be sure they don't rub the calipers.
    The 17x9's have 5.0 backspacing. You'll be able to fit 265's with those, but will need wheel spacers to run 285's.
  3. Dec 5, 2010 at 2:29 PM
    drivethruecp
    Thank you. I'll go with the 17s than and than run Spidertrax when I get my 285s. Have you seen the wheels? What do you think? Mines Super White as well. Gonna turn the white tire letters in on my current tires.
  4. Dec 5, 2010 at 2:58 PM
    KPT
    09 Prerunner
    The problem with that is that the 17's have 5.0 backspacing.
    If you get spidertrax, which are 1.25", that will effectively change the backspacing to 3.75". That will be too little backspacing (stick out too far), and the outer edge of the tires will rub the fender while turning.
  5. Dec 8, 2010 at 12:33 PM
    drivethruecp
    So I really looked today and not close to narrowing down. Although sizes are all 17x9
    Pro-Comp
    8188-7983
    7031-7983
    7105-7983
    7005-7983
    KMC XD766 Diesel W/PXD76679060300
    Motometal MO951
    M/T Sidebiter 179412
  6. Dec 8, 2010 at 1:32 PM
    KPT
    09 Prerunner
    Do all those have about the same specs for backspacing?
  7. Dec 8, 2010 at 5:16 PM
    drivethruecp
    New List w/ Back Spacing
    Pro-Comp
    7032-7983 - 4.75"
    7031-7983 - 4.75"
    ATX Thug - 4.51" or 5.34"
    M/T Sidebiter 179412 - 5"
  8. Dec 8, 2010 at 5:37 PM
    KPT
    09 Prerunner
    My voye is the thugs in 4.5" bs. Love those rims.
  9. Dec 8, 2010 at 5:37 PM
    KPT
    09 Prerunner
    My vote is the thugs in 4.5" bs. Love those rims.
  10. Jan 10, 2011 at 11:07 AM
    drivethruecp
    Pro Comp 7005
    17x8, 6 on 5.5 Bolt PatternBackspace = 4.5 in. Max Load = 2200lbsFinish = Flat Black Hub Centric = NoOffset = 0mm
    or
    17x9, 6 on 5.5 Bolt PatternBackspace = 4.75 in. Max Load = 2200lbsFinish = Flat Black Hub Centric = NoOffset = -6mm
  11. Jan 10, 2011 at 12:00 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Both of those will work.
  12. Jan 17, 2011 at 3:22 PM
    drivethruecp
    Went with the Pro Comp 7005-7883 4.5" bs, can't wait to get em in the mail!!
  13. Jan 27, 2011 at 7:01 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    I run 17x9, 0 offset, 5.0 backspace with 33's and come nowhere near to rubbing with no spacers
