whell studs to short
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeeezy, Jan 2, 2011.
  1. Jan 2, 2011 at 8:23 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    07 dbc long box speedway blue
    custom cold air intake 4 inch tubing, MBRP dual catback exhaust, readylift leveling kit with 265/75-17 on eagle alloy rims
    so just installed the spacer lift and my wheel studs seem alot shorter, its not a huge problem, i easily got the wheels on. just worried about them being weak
  2. Jan 2, 2011 at 8:25 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    spacer lift and wheel studs are not in the same realm, unless i'm missing something
  3. Jan 2, 2011 at 8:26 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    your spacer" lift " has nothing to do with the wheel studs.
  4. Jan 2, 2011 at 8:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    I'm guessing he put on spidertrax or other wheel spacers. I would suggest a shanked lug nut.
  5. Jan 2, 2011 at 8:27 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    i know thats why im as confused as you guys are.... would the diff drop have anything to do with it? maybe the axels or something?
  6. Jan 2, 2011 at 8:28 AM
    98tacoma27
    Ben
    Not Beech Creek
    No, they're not related at all.
  7. Jan 2, 2011 at 8:28 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    and i dont have spacers.....wish i did
  8. Jan 2, 2011 at 8:28 AM
    The_Hodge
    SC
    no...the wheel studs and hub area are non affected by spacer lifts, diff drops, etc.
  9. Jan 2, 2011 at 8:29 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    maybe its just my head then
  10. Jan 2, 2011 at 8:29 AM
    DrewH
    DrewH Well-Known Member
    ? this thread is fucked....are we in the outer limits.
  11. Jan 2, 2011 at 8:30 AM
    DrewH
    Yeah bro your mind must be playin tricks on ya.
  12. Jan 2, 2011 at 8:30 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    what?
  13. Jan 2, 2011 at 8:31 AM
    98tacoma27
    Ben
    Not Beech Creek
    Chances are they were that way when you removed the wheels, you just didn't notice it.
  14. Jan 2, 2011 at 8:32 AM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    probably im not going to worry about it
  15. Jan 2, 2011 at 8:36 AM
    pataco
    Down by the lake
    05 4x4 trd dc white
    :laughing: is a bit confusing, isn't it.
  16. Jan 2, 2011 at 8:42 AM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I would. Your lug nuts must have at least the depth of the diameter of the studs or you risk the lugs failing under serious load. And my guess is with the lift on, you're going to get a bit more ambitious with bumps etc.
    Fix it right and at the lest, get shanked lugs, or longer studs.
    RZ Rob
  17. Jan 2, 2011 at 8:43 AM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    Red Prerunner AC
    No really, if you look closely, the back of the wheel studs ARE connected to the top of the shock. As you lengthen the shock with the spacer, it pulls on the wheel stud, making it appear shorter. :D
  18. Jan 2, 2011 at 8:50 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  19. Jan 2, 2011 at 7:08 PM
    jeeezy
    jeeezy [OP] jeeezy
    Jesse
    Timmins
    no need to be mean lol
