when the key/truck light is flashing on the dashboard...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tac 2009, Jun 20, 2012.
  1. Jun 20, 2012 at 11:13 PM
    Tac 2009
    Tac 2009 [OP] Well-Known Member
    black 09 SR5
    does that mean that the doors are unlocked?
    cause I saw this 05 taco in my local mic ds parking lot.... all day... that light is flashing yet the doors are locked.... methinks is a stolen taco.
  2. Jun 20, 2012 at 11:14 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Red one? Might be alarm
  3. Jun 20, 2012 at 11:20 PM
    acdronin
    acdronin Well-Known Member
    "THIS TRUCK WILL SELF-DESTRUCT IN 5 SECONDS!"
  4. Jun 20, 2012 at 11:24 PM
    whopper
    whopper 2016 MGM 4x4 double cab
    wayne
    north carolina
    2016 tacoma double cab 4x4 MGM
    On going
    The flashing red key means that the engine is disabled the chip in the key turns off the blinking light when inserted . This is a security feature
  5. Jun 20, 2012 at 11:31 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    This
  6. Jun 21, 2012 at 3:25 PM
    Tac 2009
    black 09 SR5
    would you rexplain that? I reread that over and over and it makes no sense.
    the "chip in the key turns off the blinking light when inserted"?
  7. Jun 21, 2012 at 3:36 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Oh boy....
    Yells out..........
    *JAMES*
  8. Jun 21, 2012 at 3:38 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
  9. Jun 21, 2012 at 3:38 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  10. Jun 21, 2012 at 3:43 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    MAYBE BABY
  11. Jun 21, 2012 at 3:45 PM
    Tac 2009
    black 09 SR5
    do not have manual in hand. was hoping tw would help
  12. Jun 21, 2012 at 3:46 PM
    XXXX
    sKiP
    05 Prius
    We are just breaking your balls because the last guy who asked question that had some issues. Think he is on truck #3 or 4 now :D
  13. Jun 21, 2012 at 3:50 PM
    MonkeyProof
    SoCal- SGV
    I bet you can find a clip of it on youtube
  14. Jun 21, 2012 at 4:10 PM
    Jester243
    Dan
    Spokane, WA
  15. Jun 21, 2012 at 4:17 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  16. Jun 21, 2012 at 4:47 PM
    F75gunslinger
    F75gunslinger Ka like a wheel
    Christian
    Rochester,NY
    SWB '10 Doublecab TRD Sport 4x4
    Cluster and Radio LED swap,Westin bull bar,2nd set of bed tie downs,URD SS,K&N filter,weathertechs
    There is a transponder chip in the key that is "read" when the key is inserted in the ignition. The red key shaped light is an indicator that the starting system has been disabled because the receiver for that transponder chip is not "reading" the key. As soon as the key is inserted in the ignition the key is read and the truck will start. It's a security feature designed so that you have to not only have a key that is cut correctly but also have the transponder chip programmed for your truck so that it will start. It is also the reason that you don't want to lose your keys ( the replacements are expensive as f*ck! ).
  17. Jun 21, 2012 at 4:57 PM
    OZ-T
    Peter North
    British Columbia
    This
  18. Jun 21, 2012 at 6:57 PM
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    This indicator doesn't light up when I lock my truck, should I take it to the dealer to have them check it out? Does that mean my truck isn't locking and anyone could just drive off with it?
  19. Jun 21, 2012 at 7:31 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    LMAO at all this shit
  20. Jun 21, 2012 at 7:46 PM
    OffroadToy
    Are you saying the truck with the key that's inside your truck doesn't light up when the truck (the real truck, not the one on the dash with the key in it) is locked? If that's the case when you lock your truck the truck with the key woudn't light up due to the key being inside the truck.
