When to change timing chain on my 2002?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flamingskull, Jul 10, 2020.
  1. Jul 10, 2020 at 2:03 PM
    Flamingskull
    Flamingskull [OP] Well-Known Member
    Jeff
    2002 Toyota Tacoma 2.7
    When should I get my timing chain replaced on my 2002 Toyota Tacoma
  2. Jul 10, 2020 at 2:08 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    When it starts to slap against the timing chain cover?
    Supposedly these are "lifetime" chain. I don't buy it but I can attest to the chain developing no stretch after 200k miles and being run low on oil long enough that the timing cover egged out where the oil pump rides.
    I replaced the chain anyway but I'm more worried with the new one because I used an aftermarket chain and not OEM
  3. Jul 10, 2020 at 2:08 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    When you get to 250k, start thinking about it. Most likely won't need it, though.
    Abeyancer likes this.
  4. Jul 10, 2020 at 2:09 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Toyota chains are pretty stout... never seen a 2.7 chain need to be replaced. My 06 corolla with over 800k on it is still on the original chain. Typically the chains will last the life of the engine unless oil changes are neglected
    phoenix ray, Abeyancer and koditten like this.
