When to Grease?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MTLTaco, Apr 16, 2010.
  1. Apr 16, 2010 at 3:35 PM
    MTLTaco
    MTLTaco [OP] Well-Known Member
    Montreal
    09 Double Cab TRD
    I got 25000KM on my truck which is around 15500 Miles. In know that in the US the recomended time to grese the drive train is at 15000 Miles. for some reason in Canada is seems to be $32000 KM. When did you guys do it. Much appreciated
  2. Apr 16, 2010 at 3:36 PM
    jandrews
    '09 FourDubDee TRD OR
    I did it at 5k and just give everything some grease every other time I change the oil (once a year or so).
  3. Apr 16, 2010 at 3:37 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I did mine at 15,000 miles and need to do it again for my 30,000 mile tune-up here pretty soon.:cool: I just go by the maintenance manual.
  4. Apr 16, 2010 at 3:40 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Thanks for the quick response. I will start to do it every oil change. Any idea what a fair price not including the oil change would run. Forget the dealer.
  5. Apr 16, 2010 at 3:41 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Just get a grease gun and some grease and do-it-yourself. Its not very hard at all. It should take you like 15 minutes tops.:rolleyes:
  6. Apr 16, 2010 at 3:45 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Your probably right. would pay off fast.
  7. Apr 16, 2010 at 3:49 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    X2. And make sure you get a gun that has a flexible tube.;)
  8. Apr 16, 2010 at 3:55 PM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    right before penetration.....:anonymous:
  9. Apr 16, 2010 at 4:13 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Good call
  10. Apr 16, 2010 at 5:15 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    The advantage of DIY is that U no it's done. Quickie Lube will tell U U have no grease fittings or just do the easy ones. To get them all on a 4X4 U have 2 be able 2 turn the drive shaft 2 get access. Not something Quickie Lube would do.
  11. Apr 16, 2010 at 5:24 PM
    astral
    astral On my second taco now....
    Arizona
    2011 TX PRO
    U u 2 2 2
  12. Apr 16, 2010 at 5:57 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
  13. Apr 16, 2010 at 6:15 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    If you do your oil changes, grease everything that has a fitting. I grease whenever i go out in the mud and water. Grease is cheap. I buy it by the the case. it is cheaper than replacing parts...Get to know your truck :)
  14. Apr 16, 2010 at 7:25 PM
    MTLTaco
    Montreal
    09 Double Cab TRD
    Good Info Thanks
  15. Apr 16, 2010 at 7:55 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    subscribed...great post!
  16. Apr 16, 2010 at 8:18 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Gonna do it tomorrow
  17. Apr 17, 2010 at 4:58 AM
    JTDTacoma
    JTDTacoma Well-Known Member
    08 4X4 Double Cab TRD Sport
    Grab a grease gun with a flexible hose, and a piece of cardboard to lay on and DIY. Very easy to do, especially with this truck's ground clearance. There's lots of room under there while it's parked.
  18. Apr 17, 2010 at 7:01 AM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    All the grease points labelled in the owners manual? Or how many are there? Is there a specific brand you recommend?
  19. Apr 17, 2010 at 7:23 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The Canadian literature specifically states EVERY 16,000 Kms - of which 32,000 kms is one of those intervals. I would grease at every oil change at a minimum.
    Deja vu?
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/82983-first-major-service.html
  20. Apr 17, 2010 at 7:27 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Mobile1 full synthetic grease
