When's the last time you checked your spare tire pressure?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xaircav, Jun 7, 2020.
  1. Jun 16, 2020 at 4:26 PM
    #41
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Turn the tire over then you have no excuse to check it.
  2. Jun 16, 2020 at 4:29 PM
    #42
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
  3. Jun 16, 2020 at 4:30 PM
    #43
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I keep a small inflator in the backseat, so, almost never. :anonymous: Yesterday was actually the first time I messed with it, by coincidence.
    Sunday night driving home we stopped to get some root beer floats in Dublin, TX. In the midst of that sugar rush I noticed that the cover on my camper's spare was clocked 90 degrees. Odd. Investigating led to the discovery that of the two mounting bolts, one had gone missing and the other was three threads away from dumping the tire. Welp, while the cover is off, might as well top up the pressure. If it's gonna drop on I-20, I had better see maximum bounce in the rearview.:burp:
    (Fixing and remounting it yesterday made me think about the truck spare while I was at it.)
  4. Jun 16, 2020 at 5:46 PM
    #44
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    Shit. I wish I had though about turning it over befor I cranked it back up. Oh well apparently it needs replacing anyway. I’ll do it then.
  5. Jun 17, 2020 at 5:02 AM
    #45
    Gen2 Man
    Midwest
    07 Sport DCLB
    the wheel is mounted valve on top for two reasons. To protect the wheel finish especially if it’s aluminum alloy, disreguard if you got the cheap standard steel And 2 to protect the valve stem which if it’s tpms type becomes more important.
    even mounted valve up you can turn the wheel to be able to reach the stem
  6. Jun 17, 2020 at 5:06 AM
    #46
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I check mine when I think about it, haven't thought about it in 2+ years :anonymous:
  7. Jun 17, 2020 at 5:15 AM
    #47
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Twice a year....spring and late fall I check the actual pressure. But I give it a thump once in a while in between those checks. During the fall check I squirt a bit of Liquid Wrench rust inhibitor in the hoist.
  8. Jun 17, 2020 at 9:13 AM
    #48
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Stolen from the how to remove a spare tire thread...….. It's a great cheap mod.
    See this, it works great.
    Mandy3206 said:
    Ever had to remove the spare tire?
    Have you noticed that even if you practiced doing it, it's PITA to engage the rod on the elevator?
    Grab a PVC 1 1/2" sanitary pipe and cut a 14" section, drill a hole about 1" from the end and install it with a zip tie as seen in the pictures, works like a charm and total cost was $2.35 for the whole 10ft pipe.
    Why didn't Toyota did that in the first place?
    jon_elc, Joe_Seattle and six5crèéd like this.
  9. Oct 8, 2020 at 1:37 PM
    #49
    Joe_Seattle
    Joe_Seattle Member
    Joe
    Seattle
    2002 4x4 Dbl Cab TRD 5' bed
    Just regular maintenance.
  10. Oct 8, 2020 at 1:39 PM
    #50
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    October. Last October
  11. Oct 18, 2020 at 7:55 PM
    #51
    Kolby
    Kolby Active Member
    Kolby
    2015 v6 Tacoma 4WD Sport
    I check mine 4 times a year, or if im doing some wiring and I have lower the spare anyway.
  12. Oct 19, 2020 at 7:50 AM
    #52
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Each time I check the other 4 tires.
    I flipped the spare over and located the valve stem for easy access.
  13. Oct 19, 2020 at 8:21 AM
    #53
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you live in a rust state and have a steel spare, you should apply some corrosion protection to the lip where the tire seals on both sides, that area is prone to rust and eventually your spare might not hold air. The rust will gradually eat away the metal.
  14. Oct 19, 2020 at 8:32 AM
    #54
    dbbd1
    dbbd1 Well-Known Member
    I'm another one test has a tire valve extension on my spare. Mine is 36" long and routed towards to near the rear bumper, for easy access.
    spitdog and stbear like this.
