wher is the mass air flow sensor?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sslongmuir, Oct 1, 2007.
  1. Oct 1, 2007 at 5:01 PM
    sslongmuir
    sslongmuir [OP] Well-Known Member
    Maine
    95 single cab 2.7 on 33's
    Custom rock sliders
    whwer is the mass air flow sensor so i can try cleani ng it and seeing if it fixes my problems?
  2. Oct 1, 2007 at 5:26 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    It should be a few inches above the airbox on the intake tube. It should have 2 little screws holding a squarish looking thing onto the intake tube, you shouldn't be able to miss it.
  3. Oct 2, 2007 at 12:10 PM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    Look where your air filter is. On the back of the air filter box is an aluminum fitting about 3" in diameter about 3" long with an electrical fitting attached. That's it. It is connected to the engine by a plastic tube about 2 1/2 feet long and 3" diameter, which is the rest of your air intake system. Air flows in the air filter, through the MAF, through the intake tube, through the aluminum intake manifold, and into the engine. The more the better.
