Where are the holes?
Discussion in 'Audio & Video' started by Sky King, Dec 21, 2012.
  1. Dec 21, 2012 at 11:01 PM
    Sky King
    Sky King [OP] Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    I will be running coax for Sirius antannae and CB radio antennae. I don't know just exactly where I am going to locate the CB antennae yet but the Sirius antannae will be on the rear of the roof.
    I have a '07 Tacoma Crew Cab. I would like to get those two wires into the cab without drilling any holes if at all possible.
  2. Dec 21, 2012 at 11:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Sirius/GPS I ran out the 3rd brake light housing and sealed with RTV.
    CB you can run out the floor of the cab under the carpet/seat.
  3. Dec 22, 2012 at 6:12 AM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    If you remove the back panel under the back window there is a small rubber plug and hole on each rear corner of the cab, Perfect for coax.
  4. Dec 22, 2012 at 9:02 AM
    Sky King
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Thanks. This is a crew cab or as some call it, an extra cab. So these will behind the rear seat backs? When folded forward, there are storage areas behind the seats. Are you referring to the back panel of the storage area?
  5. Dec 22, 2012 at 9:14 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    easiest way to do it. simple and quick with no wear issues on the wire. mine has been like that for 4 years. took me all of 10 minutes to run the wire from the radio to the taillight and I only had to pull the sills and kick panel.
  6. Dec 23, 2012 at 7:59 AM
    Buff
    Buff
    NEPA
    V6 TRD Sport 4x4
    Look on the outside between the cab abd the bed. You should be able to see the rubber plugs near the bottom of the cab.
  7. Dec 30, 2012 at 7:03 AM
    RetiredPunk
    RetiredPunk Member
    troy
    Va Beach , Virginia
    13 Tacoma Dcab trd 4x4
    The antenna puck will mount on top and if the rubber plugs are on the bottom of cab theres going to be atleast 6 ft of coax visible correct ? what or how did you guys hide that ?
  8. Dec 30, 2012 at 9:37 AM
    XXXX
    sKiP
    05 Prius
    this is why 3rd brake light it the best IMO. 2" of exposed wire max.
    Mine has been on for 4 years with a magnet mount low pro antenna and never had an issue. Wire is totally hidden behind the rear panel without even removing it. Just had to remove door sill plastics and 3rd light then tape it off for a nice caulk joint and seal it with a good product.
  9. Dec 30, 2012 at 9:59 AM
    RetiredPunk
    RetiredPunk Member
    troy
    Va Beach , Virginia
    XXXX, Did you have to tear into the head liner ? Or touch it at all ? Im trying to avoid it at all causes , unless its not as complicated than im making it in my head ? You got a pic or does anyone have pic s ... Thanx
  10. Dec 30, 2012 at 10:26 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I removed the dome light and coat hangars above the back window
    Poke a screwdriver under the hook to depress the release, rotate 90 degrees, and remove....
    Or do what I did... twist the snot out of them and the tabs will break, then reinstall them and the next time you order Toyota parts, order replacements ;)
    This will free the rear of the headliner.
    Pull the weather stripping away from the top of the door(s).
    Remove the A-pillar cover. Remove the B pillar cover. Remove the visor.
    This will free the edge of the headliner
    I ran mine down the passenger side, because I mounted my Sirius receiver behind the passenger kick panel, and the area behind the glove box is fairly uncluttered so it was easy to run the GPS antenna and harness for the Sirius receiver.
    My hands and arms are skinny, so I am able to reach into the stereo opening, poke around a bit, and "shake hands with myself" with the other arm reaching in through the glove box.
    WAY easier than routing things around on the cluster side of the dash with the brake/wheel/clutch and other moving parts to avoid.
  11. Jan 1, 2013 at 8:10 AM
    RetiredPunk
    RetiredPunk Member
    troy
    Va Beach , Virginia
    Thanx Rich ... Ill be most likely doing that .
  12. Jan 2, 2013 at 9:11 AM
    XXXX
    sKiP
    05 Prius
    No removal was done at all. I barely touched it. I have no pics (did it 4 years ago). Super easy in a access cab from 2008. I did have a friend helping me so I pushed it to him by hand.
  13. Jan 2, 2013 at 1:41 PM
    RetiredPunk
    RetiredPunk Member
    troy
    Va Beach , Virginia
    Ok , i got under the headliner by just taking the 2 coat hanger plastics off counterclokwise . My next question is i removed the red brake light lens cover off and pulled like hell on it and the plastic bracket would not budge . I then went inside cab under headliner and felt around for brake light bracket fasteners but couldnt put my hand on anything that felt like an inside fastener . Are there inside fasteners that the brake light fastens with ?
