Where are you getting your oversized tires installed at?
Discussion in 'Wheels & Tires' started by SomeTacoDude, Nov 1, 2024.
  1. Nov 2, 2024 at 6:27 PM
    MGMDesertTaco
    Depends on the manager working that day. I've asked. ;)
  2. Nov 2, 2024 at 6:30 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Walmart installed my 35" Kenda Klever R/Ts for free after they couldn't balance them. But I've never had any bad vibrations so score other than waiting around for them to finish like a dumbass
    Side note : to get around the "we can't do non doorjam", bring them in with a different vehicle so they don't even know what it's being installed on.
  3. Nov 3, 2024 at 9:38 AM
    SomeTacoDude
    SomeTacoDude [OP] Well-Known Member
  4. Nov 3, 2024 at 10:08 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Went right passed it. Shop by size not vehicle. The in the cart it gives you the option to continue to cart w/o vehicle info and schedule appointment.
  5. Nov 3, 2024 at 3:55 PM
    SomeTacoDude
    I understand this. But this is policy across the board. So it's up to the management at each store to follow it or not. The store I have dealt with follows it.
  6. Nov 3, 2024 at 5:24 PM
    gotoman1969
    That’s crazy. Then I guess they’ll stop carrying any oversized tire from all the manufacturers.Gonna cost them a shit ton of business from the truck world.
  7. Nov 3, 2024 at 5:28 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Order my tires online and my local, independent Toyota Shop installs them for me. Only one size up from stock/door jamb size though.
  8. Nov 4, 2024 at 4:28 AM
    InThePlains
    InThePlains Well-Known Member
    Yep and the guys at my local shops know their stuff.
    Costco sucks balls, slow as hell, too.
  9. Nov 4, 2024 at 11:38 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    In my garage at home.
  10. Nov 4, 2024 at 8:48 PM
    radbrad311
    radbrad311 Member
    2023 DCLB TRD OR
    Interesting, maybe state specific. I can’t get that message to show up and it even gives the option to select oversized tires.
  11. Nov 4, 2024 at 8:58 PM
    kimosabe15
    kimosabe15 Well-Known Member
    2015 DCSB SR5
  12. Nov 4, 2024 at 8:59 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Go to a different tire shop or off-road/4x4 shop. Does 4WP mount and balance tires?
    For really large tires (38"-40" or bigger) you can try a commercial truck tire shop.
  13. Nov 4, 2024 at 9:17 PM
    MGMDesertTaco
    What do you use? Starter fluid and match? Giant tire iron and a tub of Crisco? Or are you fortunate enough to have tire installation and balancer machines?
  14. Nov 5, 2024 at 5:35 AM
    BDSKJChris
    Albany, NY
    I modified a manual tire changer from harbor freight to use a hunter duckbill and made the center post tall enough to allow the setup to clear a 12.5" wide tire. I bought a balancer used from a dealership, cleaned it up good and now I never have to deal with tire shops again.
    To be honest, installing the tires is surprisingly easy on the manual changer, the only way I would ever buy an actual machine would be if I scored an insane deal on a good center clamp machine.
    Details here: https://www.tacomaworld.com/threads/garage-shop-tools.589784/page-317#post-29958282
  15. Nov 6, 2024 at 12:58 AM
    #35
    Sig Taco
    Sig Taco Well-Known Member
    2021 Taco DCSB
    Icon Rebounds 17x8.5 Toyo 35/12.5/17 JBA UCA, Bilstein 6112/5160, KDMax
    DT installed my 285/75/17 and .75" wheel spacers. At that time I could barely turn the steering wheel due to rubbing before my alignment. Less than $100 otd. They switched my tire sensors into my new wheels for me as well.
    Last yr they installed 35/12.5/17 that I ordered online from them. They rebalanced and rotated them for me after 8K miles. Less than $100
  16. Nov 7, 2024 at 4:09 PM
    #36
    SomeTacoDude
    This post would make me inclined to believe you are right. That would explain a lot of this.
  17. Nov 8, 2024 at 5:10 AM
    #37
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    https://www.tacomaworld.com/threads/new-support-option.835393/
